Question about Fujitsu Siemens AMILO Pro V1000 Notebook
Dial up Modem
I want to install Netzero as my internet service. It won't connect and I'm told by Netzero support that my Dial Up Modem is missing. How do I get a Dial Up Modem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 274 Answers
Dial up modems have 2 phone line connections side by side in the back of a desktop, one is for the wall, other is for your telephone. Laptops have just one phone line connector. Look closely at the little symbols by the connection holes. If you don't have one, Modems (internal or externally mounted), are on eBay, buy a 56K with drivers on disk for your operating system. A few modems can be installed using Windows default drivers (drivers are software operating programs that tell your computer how to regulate and operate a device).
Posted on May 13, 2016
Internet connection
Depends on your system, install modem first then the system should ask for drivers. Make sure your dial up modem drivers are appropriate to your operating system. Try the modem in a different slot, some modems are not compatible with some motherboards. If the My Computer/System/Device Manager can't see the modem, you have to try another modem or slot. Then install or Update drivers once the system sees it and will show Properties of it.
Aug 19, 2009 | Compaq (198721-001) Modem
Netzero connection problem?
A modem is a device that allows you to use a voice telephone line to connect your computer to the internet. If you contact NetZero Tech Support, they will send you a CD to run through the setup. The modem connects to the wall with a standard telephone wire. (The ends are known as RJ11)
Aug 15, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
Install BlackBerry Desktop Software 4.1 or later on your computer.
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Modem for dial-up
Well I hate to be the one to break the news but their is no such thing as a fast modem. They are all 56Kbps which is slow....the only fast modem is a DSL modem, but that is outside the computer and it gets hooked up with your phone company or your Internet Service Provider. Check the invoice or packaging slip and see if it says "DSL Modem capability"..if so then you are ok but your ISP has to install it.
Dec 28, 2008 | Gateway Computers & Internet
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Compaq Presario.Pentium 4, Vista Windows Home basic. Model SR504OAN Purchased 2007, My son Had Broadband only. Want to use dialup. How do I assertain whether it has an internal modem. On Modems in...
Ok. You want to setup a new Dial up connection.
First, you need to call a service provider and sign up for service with them. Here are a few companies.
  • AT&T Dial - 1-800-524-8500
  • Netzero - 1-888-349-0029 or online
  • People PC - 1-877-947-3327 offer code WEB6
Netzero provides 10 hours free per month with ads.
Personaly, I've had People PC and their customer service is great. On the contrary, I've had Netzero and their wait is at least 2 minutes for a representative. AT&T has also a good customer service.
The service provider you choose is up to you. All of these companies offer speeds of 56Kbps, which is the fastest you can get with dial up. People PC and Netzero offer "internet accelerators".
After choosing, they will send you a CD or you can download their software online.
Click here for PeoplePC.
Click here for Netzero.
At&T does not have their software online.
You already have an internal modem so just install the program and thats it.
Hope this helps.
Aug 05, 2008 | HP Computers & Internet
Dial up?
Technically no, not unless the PC where the modem is connected to is used as a Gateway/Share Internet Connection and is connected to the WAN side of the router. However, this arrangement would need a lot of manual configuration and settings on the modem side PC as well as the client PCs.
Alternately, you may be better off connecting the modem PC to a hub rather than a router and set static IP adds on the client PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 24, 2008 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Dial up connection
Go to Control Panel
Internet Options
Connection Tab
Click Never Dial a Connection
Click OK
If you are using AOL, Juno or NetZero, then the dial configuration is in that software application
May 17, 2008 | Computers & Internet
Modem Driver Problem
I need of the drivers FB pctel amr
Apr 28, 2008 | Computers & Internet
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Fujitsu Siemens AMILO Pro V1000 Notebook Logo
172 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
