Question about Tascam 2488 Portastudio Multitrack Recorder System
Multi Effects Hi. I posted this also. I assign a multi effect to channel 2 with no problem. Then when I go to channel 3 or 4 and assign a multi effect over a different part, I LOSE the effect I placed on channel 2... Any suggestions?
    Scholar:
  • 141 Answers
I am not a tascam expert, but I would guess that you can't assign different multi-effects to 2 channels at once.
Posted on Sep 08, 2008
I can't find the in line connector
71audio1.jpg Item Description A Rear left/right out (multi-channel audio) B Line in C Line out (2-channel) or front left/right out (multi-channel) D Mic in (re-task for multi-channel) E Center/Low Frequency Effects (LFE) out (multi-channel) F Optical S/PDIF (Toslink) line out G Optical S/PDIF (RCA) line out
Sep 02, 2011 | Intel D946GZIS Motherboard
For seven months am having some pain in my left leg joins. Its not a pain its like irritating. Last week when I take the MRI scan, we found that bone got bulged and touch the Vein Path. And doctor...
Question (Posted on : 11 Aug 2009 )
What is Renerve Plus prescribed for and what are the side effects of the same?
Doctor's Response (Posted on : 17 Aug 2009 )
Renerve plus is a multi vitamin and anti oxidant combination.Contains Methylcobalamine,inositol,alpha lipoicacid, calcium,chromium etc.Prescribed for general well being and especially when there is weakness. No notable side effects.
A quote from Clinovo Research labs reads "Renerve plus is a multi vitamin and anti oxidant combination.Contains Methylcobalamine,inositol,alpha lipoicacid, calcium,chromium etc.Prescribed for general well being and especially when there is weakness. No notable side effects." I have found no information leading me to suspect it is anymore useful than any other multivitamin. I recommend you get an opinion from another doctor.
Sep 03, 2010 | Health & Beauty
How do I assign Vocal effects to a track
You assign the effects basically the exact same way you assigned the channels to inputs, except you press and hold the "MICX4" button and press the "Select" key to the channel (or channels) you want to assign the effects to. Once you assign the effects to the channel, you can edit to the effect you want, and edit the values of the effect.
Good Luck!
Aug 14, 2009 | Tascam 2488 Portastudio Multitrack...
Effects won't record or play back
Turn on the effect for the appropriate input or turn on the reverb. For the reverb you must turn up at least one tracks (the track you are using) effects send together with the Master effects return. The volume of the multi effect may need adjusting or the parameter of the effect is so low that the effect is too subtle to be noticed. Multi effect page 60 of the manual. Manual can be found at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 28, 2009 | Tascam DP01 All-In-One Recording Package...
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
Nov 30, 2008 | Tascam 2488 Portastudio Multitrack...
Understanding the multi effects on the 2488
Hi rmkuzma
You are not recording the effect to track, it is probable that you are perhaps using the effect loop, it will not be recorded to track this way. This how you should really record anyways so that you can go back and change the effect or even just fine tune it in the mix, you can then bounce the track later with effect if you want later. If you want the effect to go to track then
1. Press and hold the MULTI button, then press
the SELECT button on the channel you want to
assign.
2. Press MULTI again to view the effect parameters.
Press the ENTER button to choose an effect
that you want, tweak it for what you want, and it should then go to track
Try that and see how you go. I am happy to talk to you more about it. A FixYa is a good reward for my efforts to help you out. Cheers mate
regards
robotek
Oct 19, 2008 | Tascam 2488 Portastudio Multitrack...
Multi Effects?
Here's a run down of the 2488 effects. It should explain how to use them.......
Effects processors can be inserted into the appropriate channels simply by holding the required effect mode button and pressing the required channel selection button. When the effects are configured as eight channel insert effects, the processor can provide compression, de-essing or exciter functions (selectable independently in each of the eight installations).
If you only need four such insert effects, then you can substitute a single multi-effect processor for the other four. This multi-effect is most likely going to find its way into the guitar DI input, and offers a chain of effects starting with a noise-gate followed by either distortion or compression.
If you are happy to abandon channel insert effects entirely, then you can set up the effects block as a single send/return processor which provides somewhat higher-quality effects. Algorithms include reverb, pitch-shifting, delays, and so on, and are accessed by dialling in an amount of Loop Send from any appropriate mixer channels. There is no dedicated effects return channel as such, but the level of the chosen effect can be adjusted in the relevant control screen.
Full article at: http://www.soundonsound.com/sos/may04/articles/tascam2488.htm
Sep 03, 2008 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Mic effects
The short answer is that you'd use the multi effect (or one of the 4 mic effect) to one channel for effecting your mic input. Reverb should be added later using the single effect. You'd send the already recorded track to the send effect and then return it to another track and 'print' it using a bounce. 'Send' sends the signal to the effect and returnsit to the mix bus. So to add reverb to a track you'd send that track to the single effect after configuring the reverb effect the way you'd like it, and then make sure all of the other are turned down and record it to an open track during a bounce.
The single effect is what would be referred to as a 'send effect' and is designed to be used at mixdown or during a bounce. In the 2488 the single, aux and send effects are all 'send effects'. These take an existing sound and change it. Examples are reverb, chorus, delay, phaser and flanger. The internal effects on the 2488 can be used or external sound processors can be fed with the sends and returned to inputs on the 2488.
The 2488's multi-effect, as well as the mic x4 effects are 'insert effects' to be used on the input signal when recording. Examples of insert effects are compression, expansion, gating, limiting and distortion.
You can send all channels (or multiple channels) to the same effect send, but they all must be sent to the same effect (or chain of effects) at once. You cannot for instance send channels 1,2 and 5 to one send effect and 3 and 4 to another at once. You'd have to do something like that in two seperate operations.
Insert effects cannot be shared among channel strips. Each sound source needs its own insert effect. The 2488 has one multi-effect box which acts like an effect chain on one channel or 4 mic effects which can be assigned to 4 mic inputs at once. Each input assigned uses one of the mic effects up (a stereo pair will use 2) of the available 4.
The main thing to remember is that there are the 2 different effect types. Sends are for adding something to the signal like reverb, chorus, delay, phase shift, flange (on the 2488 these are the single effect and the aux send effects) while insert effects act on the signal modify or subtract from it (compression, gate, limiter, distortion).
Hopefully this helps. I know it can be quite confusing starting out.
bd.
Jun 26, 2008 | Tascam 2488 Portastudio Multitrack...
Using the effects on the 2488 mk 11 for vocals
Use a single effect vice a multi effect and assign it to the channel vice the input and that should get you going. I'm sure you could just set the effect to the input and not the channel but this works for me. If your tracking your instruments/tracks to different channels, and you should be, then assigining the effect to the channel wont hurt you.
Apr 05, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
102 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
