Question about Pioneer Televison & Video
Pioneer dvr-320 will not turn on -- power is not getting to the unit....i suspect a problem in the power supply board.
You can get a new power supply board. $66 delivered.
Posted on Nov 25, 2009
Power supply unit failure
It could be the IC101 (MR2920) and the zener D104 both failed, or IC1 (MD5001T) failed as well, here is the link where I've descrived how I fix the issue on my DVR-520H, it is in italian but you can translate it with Google:
Feb 08, 2013 | Pioneer DVR-520H DVD Recorder
My 720 dvr turns itself off and can only be turned back on by unplugging it from the power source?? Whats the issue here?
Thank you for waiting, your problem is commonly caused of leaky filter electrolytic capacitor in the power supply section, it will affect the regulation of the supply and sometimes need a little warmp up to back from functioning. The symptom will get worst if didn't replace the capacitor. Once isolated your unit will back to normal again.
Hope it may help you.
Give a thumbs if you find it useful.
Have a nice day!
Feb 09, 2011 | Pioneer DVR-720 DVD Player/HDD Recorder
My Pioneer DVR 320 dvd recorder just stopped working. Iv'e checked the power source thats Ok. Is their a fuse or something or is it old age?
Tries unplug,replug the unit back like about an hour later,see if might just in it protected mode,see if the unit reset itself and work again.Yes,there is a fuse in the back of the PCB board,it seat near the power a/c cord.U can tries to replaced the fuse and tries it out.But all modern electronic devices saldum burn fuses in a normal uses.
Jan 29, 2011 | Pioneer DVR-320S DVD Recorder
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Jan 11, 2011 | Televison & Video
As of the last 30 days or so the pioneer pdp 5070
I had the same thing happen...come to find out, the main board and power supply on these units seem to fail quite frequently...that's about a $1200 bill to repair!....mine's in the garage behind some shelfs...I purchased a new Samsung LCD after Pioneer wouldn't help, despite being only 2 months out of warranty...glad they're getting out of the plasma business so they can't "stiff" any more folks....
Nov 29, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
I need a dc power cord for the Pioneer DVR-X152 Where can i get it and what is the part number.
This is the info on the power supply that came with my DVR-X152.
Asian Power Devices Inc., APD Model No. DA-30C01
Oct 18, 2009 | Pioneer DVR-X152 DVD±RW Dual Layer Burner
Pioneer DVR-320-S is dead.
Well if it is dead and the transformer is getting power then next step is the processor.  Which if it is dead, then I am sure all the internal components are as well.  My recommendation is have a professional give you and estimate and buy a UPS unit that will regulate the power to you important expensive units such as this.
Jan 06, 2009 | Pioneer DVR-320S DVD Recorder
DVR-720 power off
I have a solution to power it on again quickly. Unplug the power cable, short out the pins in the power socket in the back of the machine ( NOT THE POWER CABLE ) and plug the power cable back in - it should go into standby mode immediately. I think the problem is caused by a capacitor on the power supply board going faulty with age. I have not had time to open the machine to check yet, but I will do so soon.
Nov 09, 2008 | Pioneer DVR-720 DVD Player/HDD Recorder
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
Televison & Video Logo
533 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
