Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Dryer wont start
Dryer will not start when switch is turned
  • Anonymous Oct 02, 2008
    Dryer won't start when start button pressed. Hear a slight buzz. Model GLEQ2152ESO.
    Sergeant:
  • 409 Answers
sounds like it's the touchpad or control board. please provide the brand and model #.
thanks.
Posted on Sep 25, 2008
Dryer wont turn on
Lots of things it could be. I'd try the shut-off switch first.
There is a switch that is supposed to turn off the dryer when you open the door.
That switch is often made of plastic, and can break or even fall out inside the machine.
After that, I'd check the start switch to see if it failed.
Be blessed.
Feb 17, 2013 | Crosley CDE6000 Electric Dryer
Electric dryer wont start. Door switch turns light on/off. Timer is heard ticking. Press start... nothing. Tried bypassing all parts in the back.. Thermostat, thermal fuse... still nothing. Could it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Kenmore 62602 Electric Dryer
Drum wont turn but dryer heats.door switch and push to start switch ok. No hum or buzz from motor.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jun 24, 2010 | KitchenAid KEYS750LQ Electric Dryer
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
Dryer starts but wont stay on
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Jun 14, 2009 | Kenmore Dryers
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start
its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Jan 29, 2009 | Frigidaire FDE336RE Dryer
My ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Dec 16, 2008 | GE DWXR483EBCC Electric Dryer
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
