Ovens Logo
Posted on Aug 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Smoke coming out of lg convection microwave oven while pre-heating. Does that usually happens?? is it safe to use that microwave?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
  • Posted on Aug 09, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
0
Helped
32585
Points
686
No it is not safe you will be better to buy one. SORRY i could not help you it better to be safe then sorry
Bosch convection microwave HMC87151UC does not heat in convection mode.
The issue you're experiencing with your Bosch convection microwave not heating in convection mode could be caused by a few different things. Here are a few things to check:
  1. Check the settings: Make sure that the microwave is set to convection mode and that the temperature and time settings are correct.
  2. Check the element: The bottom heating element is responsible for providing heat during convection mode. Make sure that the element is not damaged or burnt out. You can visually inspect it, if it is damaged it will need to be replaced.
  3. Check the fan: The fan is responsible for circulating hot air during convection mode. Make sure that the fan is not blocked or damaged. If it is, it will need to be replaced.
  4. Check the control board: The control board is responsible for controlling the functions of the microwave. A malfunctioning control board could prevent the microwave from heating in convection mode.
  5. Check for a blown thermal fuse: A thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse is blown, it will need to be replaced.
  6. Check for a blown thermal cut-off: A thermal cut-off is a device that cuts off power to the oven if it overheats. If the thermal cut-off is blown, it will need to be replaced.
Dec 23, 2022 • Bosch Ovens
2answers
Microwave is smoking when I use it as a convection oven
It seems to be self cleaning... burning all the oils that coats the inside from microwaving food that wasn't covered. Clean the oven well and to remove bad smells put lemon juice in a bowl and microwave.
http://www.wikihow.com/Remove-Odors-from-a-Microwave
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
1helpful
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
1helpful
Frigidaire Oven making vibration noise when Pre-Heating or Convection cooking. Only notice when convection fan is running.
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
try using a voltage stabiliser .it may just solve ur problem..
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 • GE Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
