Question about eMedia Music Corporation Guitar Method Vol. 1 (EGO9971) for PC
Emedia guitar method 1
I can't run this software with windows 2000xp can you help please?
Using a previous compatibility mode would be a stop-gap solution. The permanent fix would be to upgrade the software to a Windows XP compatible version.
http://www.emediamusic.com/support/upgrades.html
Posted on Sep 04, 2008
Tip
How to play guitar using a computer
<p>Playing a guitar using a PC at home is a simple process that some audio devices and a computer to an analog line or microphone port on your sound card to obtain. There are two kinds of freeware, that a user can provide to the task. Basic freeware that standard on any Windows computer, including audio drivers free, microphone input, even if the computer's speakers to play. Users to make recordings of your own burning freeware, however, were interested in Windows freeware called "Sound Recorder" can do the work in the most elementary sense. <br /> <p><br /> <p>1. Plug the Phono-style audio cable into the guitar phono audio jack. <br /> <p><br /> <p>2. Connect the large to small-RCA adapter to the end of the other side of the RCA cable. <br /> <p><br /> <p>3. Connect the adapter cable and phono large on the back of the computer through a computer microphone. <br /> <p><br /> <p>4. Adjust audio properties of the system from the Start menu and Control Panel of your computer to play audio into the microphone port on the speaker. The exact process of adjusting the settings may be proprietary software, the sound card came with the computer system vary. If you have problems, ask the help documentation for software and manual for your computer sound. On most systems, the microphone volume level using the properties menu of the extended microphone system sound settings. <br /> <p><br /> <p>5. Set the switch to the guitar pickup - the pickup is a version of power - the "on" position. Adjust the volume on the computer so the computer speakers clearly the natural sound of the guitar can be heard. <br /> <p><br /> <p>6. Play a few notes on the guitar. If your computer speakers to play the guitar sound, the method proved unsuccessful. <br />
on Jun 22, 2011 | Computers & Internet
I have a pcg272l Sony viao how do you get the key board and mouse to work
I would suggest you to follow the methods given below. Before we proceed, please answer the question given below.
1)What is the program that you were trying to run?
I would suggest you to follow the methods given below and check if it helps.
Method 1: Run the Hardware troubleshooter and check.
Follow the steps to run the troubleshooter:
a) Press Windows key + C on your keyboard to show the Charms bar.
b) Type Troubleshooting and click Troubleshooting under Settings.
c) Now type Hardware Troubleshooter in the search option.
d) Click on Hardware troubleshooter to run the troubleshooter.
Also try updating the drivers for Keyboard and touchpad.
Method 2: Update drivers for Keyboard and touchpad.
a)Press Windows Key + R, type devmgmt.msc.
b)Right click on Keyboard.
c)Click on properties, click on Driver tab.
d)Click Update Drivers button.
e)Click on OK button.
Similarly follow the steps to update the touchpad.
Method 3: Run Microsoft safety scanner.
The Microsoft Safety Scanner is a free downloadable security tool that provides on-demand scanning and helps remove viruses, spyware, and other malicious software. It works with your existing antivirus software.
If not Solved i share a link please visit it.
https://us.en.kb.sony.com/app/answers/detail/a_id/33607/~/-the-keyboard-and-touchpad-do-not-work-in-the-operating-system,-but-keyboard
Thanks,
Mac Customer Service
Jun 17, 2014 | Computers & Internet
How to play the song where are you now by justin bieber?
you might need this video tutorial:
hope it help you and
have a nice day :)
Apr 17, 2010 | eMedia Music Corporation Piano And...
Trying to get it to run in vista and get an error "illegal function call"
In most cases Illegal Function Call Errors (or General Protection Faults) are caused by Windows Memory leaks causing insufficient memory to be available to perform the requested function
Dec 20, 2009 | eMedia Music Corporation Guitar Songs Vol....
Emedia guitar master not able to run after installation
Windows® Vista Error on launch:
“Director Player has stopped working” or “Macromedia Projector has stopped working” Most likely this problem is solved with the following steps:
  1. Click the “Start” menu and launch “Computer” from the right hand panel
  2. Navigate to the eMedia Guitar Master installation directory (typically this is inside your C: drive > “Program Files” folder)
  3. Navigate to the “Xtras” folder within your “eMedia Guitar Master” folder
  4. Delete the file called “SequenceXtra_1_9.x32”
Launch Guitar Master. It should open properly.
If the above solution fails to eliminate the problem, take the following additional steps:
  1. Click on the “Start” menu and navigate into the folder to the eMedia application.
  2. Right-click on the program icon and select “Properties.”
  3. In the box that pops up, select the “Compatibility” tab.
  4. Check the box “Disable visual themes.”
  5. If you can, check the box “Run this program as an administrator.”
  6. Click “Apply” and then click “OK.”
If you continue to experience problems with Vista, please make sure that your system is up to date. Download the latest updates for your operating system at support.microsoft.com. Get the latest version of QuickTime at www.apple.com/quicktime/download.
Dec 29, 2008 | eMedia Music Corporation Guitar Songs Vol....
Windows 98
Have a read of this MS article. It contains everything you need to do/know
http://support.microsoft.com/kb/306559
Hope this helps.
DarkmanUK
Please remember to rate.
Aug 27, 2008 | Computers & Internet
No effects
Double click on your speaker icon in the task bar next to the time (Or go to audio in control panel and find advanced settings)
Look for microphone and line in and mute them ...
Then click options, Goto advanced and choose recording and click ok ... Look for the input your using and turn that up as much as you need.
Then check guitar rig ... All should be fine now
Jun 25, 2008 | Native Instruments GUITAR RIG
Open Questions:
Acer Virus Removal ' Remove Acer Virus - DataAlign ' Call +1888784-9316 Since those early days of laptop production, Acer has grown to offer devices in just about every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. While many consumers consider products made by companies like Dell or Sony to be at the higher end of the laptop spectrum, savvy consumers are beginning to realize that although they are priced competitively, support acer laptops do not lag behind in quality at all. As the company continues to grow, there is speculation that they may also enter the tablet and smartphone markets as well. For the all-round support of Acer customers, we have trained a team of highly skilled, certified engineers with excellent knowledge for all issues particularly faced with Acer products. Technical support is provided 24/7 every day on our toll free helpline called acer computer support number. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues All these issues can be resolved by our round the clock available highly experienced tech support team with dedication and professional attitude, contact acer support. Our services: Get all your queries, issues and complaints sorted out most efficiently and in the least time with most effective results that stay for the longest duration by contacting our Acer Support team members by calling on acer customer service. Contact our technical support team for any assistance regarding issues concerning Acer Products by acer product support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 20, 2018 | Acer Computers & Internet
See all eMedia Music Corporation Guitar Method Vol. 1 Questions
eMedia Music Corporation Guitar Method Vol. 1 (EGO9971) for PC Logo
168 people viewed this question
Top eMedia Music Corporation Computers & Internet Experts
David Payne
David Payne
Are you an eMedia Music Corporation Computer and Internet Expert? Answer questions, earn points and help others
