Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F 11 ERROR KEEP BEEPING
F 11 ERROR IN A WHITE RANGE (FRIGIDAIRE )_
WHAT TO DO ,
  • 4 more comments
  • j13reyes Sep 19, 2008
    My problem is almost the same, it shows F1 and it's keeping BEEPING. I tried to on and of it from the circuit breaker but after a minute its start beeping again. BUT, the 4 burners are working except for the oven because all buttons are frozen.
  • bdobbe Oct 02, 2008
    My Frigidaire oven had a F1 error code and I replaced the EOC as per repair forums. Now it is beeping again and showing the F11 error code. The online forums suggest replacing the EOC when the F11 error code appears. I've done that and need to know what step is next.
    Thanks, Brian
  • nasys Dec 07, 2008
    i have the same probleme f11 showing i disconnected the oven for a full night periode but in the morning when i plugged it back on started bipping again. what is the EOC exactly?
  • stumpedintx Dec 08, 2008
    i get the same issue but i've noticed the broiler heating element (on top) comes on instead of the oven (on bottom)....any ideas what to do about that? everything else seems to work fine.
    i have the same problem...the broiler elemnt (top) comes on instead of the oven (bottom) when i hit bake...everything else is fine....don't know what to do....sometimes the bottom one comes on but it will switch to the broiler when the temperature has to readjust and then it burns everything
  • Anonymous Jan 21, 2009
    I have had the same problem for the last 5 days. Getting the F11 beeping noise and I shut the stove off and tried resetting it. Is there a option to reset the stove or program functions.
  • 116 Answers
F11 - usually associated problems with the key pad. Shorted or otherwise malfunctioning. If power is disconnected from the unit for about 30 - 45 seconds and then reapplied and the problem still exists changing the EOC is recommended
Posted on Sep 04, 2008
My oven is keep beeping and I can't cancel it
Good Morning Friend, that's a great question!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 13, 2014 | Frigidaire Ovens
How do I clear a f 11 fridgedaire oven
Good Afternoon Friend, this is Z. I appreciate your post!
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Jul 31, 2014 | Frigidaire Ovens
My frigidaire stove I have to umplugg it because keeps beeping f10 can' stop I push any bottom and keeps beeping
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Thanks,
Chris
Dec 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire beeping with F10 signal
sounds like you need to get all food out and switch it off and leave the doors open and leave it for two days with the doors open ok then afther you have left it swich back on with doors closed do not open doors for 24 hours swicth on ok then it should be ok if not then its lack of gas
Oct 15, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire electric range keeps popping an F93 errror. i was wiping out the inside and probably accidentally touched buttons on the touchpad. ive tried flipping the breaker, but it just keeps beeping...
Hi - Typically error code F93 indicates a communication problem with the console control. Since you have already try to reset the unit and unfortunately it was not successful, I would suggest contacting a professional to move forward and replace the main control board.
Oct 06, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire range ffef3016lbe flashing f-11
You have a shorted out keypad - (F11, 12, & 13) disconnect power, wait 30 seconds and reapply power. If fault returns upon power-up, replace EOC
Aug 21, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F10 DIsplays on oven and beeps frigidaire oven with flat top
Go to the Frigidaire web site if you don't have the manual and download it. I saw the F errors listed. They even have the electrical drawings.
Apr 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
1,284 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
