Question about Jenn-Air JES9800A Electric Kitchen Range
Jenn-air shut off while cooking giving f9 code
While cooking, slide in stove shut down, beeped continuously, displayed F9 code. I turned it off and tried restarting. 'The door tried to lock as if going into cleaning mode, then beeped, displayed F9 and shut down. Will no longer cook. Help my turkey is only half cooked.
  • Anonymous Nov 27, 2008
    I have the same problem
  • Anonymous Dec 15, 2008
    I have the same problem. My Jenn-Air slid-in stove-oven stopped cooking and started beeping and I got the F9 code. Now the oven won't heat up properly. I've tried taking removing the cooktop and pushing the reset button and that doesn't help.
Code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Posted on Jan 16, 2009
Jenn Air Kitchen Range Model jer8650 oven stopped working and code f9 appeared
Try shutting it down at breaker then back on. This helped me.
Mar 16, 2013 | Jenn-Air Kitchen Ranges
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F9 code
says F9, is a problem with door lock saftey circuit. replace power relay board
Mar 01, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Beeping noise - letters appear fc
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Function Problem
Paul, the F9-3 code has to do with the oven door lock motor assy.. Water must have gotten on to it and now the fault. There is a quick test mode on the model ending in aab, if yours ends in this try this. Unplug the oven for 30 seconds, plug it back in and press and hold the cancel and broil buttons together. It should enter test mode. When in the test mode press the clean button to see if the motor activates and resets. Press cancel to exit the test mode...Catriver...post back
Aug 15, 2006 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
1,482 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
