Motorola 6200/6416/2708 Receiver changes channel by it self
TV will not display picture or sound except for 1 station which appears to be 440. I can't change the channel either at the dials or remote. The display says EAS.
DONT USE the remote that came with your TV
use the buttons on the box to change the channel. did the channel change?
usually when someone only has one channel its because they are changing the tv channel not the cable box channel
think of it like this:
the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel.
so if you change the tv channel you are no longer watching the output of the cable box.
USE the remote supplied by your cable provider
Aug 06, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
I have a Motorola DCT6200 DTV Receiver and the remote I am using for the device is not responding. I can still turn off my physical TV with the remote, and can still change channels on the Receiver itself,...
wrong mode!!!!!
put your remote back in cable mode and you will be back to normal.
usually up near top sometimes push "mode" then "cbl" sometimes just push "cable"
good description of problem, I can tell your a thinker.
99% sure this is your problem though
good luck
Dec 27, 2010 | Arris DCT6200 DTV Receiver
MY REMOTE WILL NOT CHANGE CHANNELS ONLY TURNS TV ON OR OFF
After much trial and error, we discovered a temporary fix. We taped a 3 x 5 index card to the front of the box directly to the right of the time/ channel number. The remote will change both the channels and the sound level with this "fix." Could there be some kind of emission coming from the box that interferes with the remote? Maybe Motorola could put a more opaque front on the box.
ympm
Jan 11, 2009 | Arris DCT6200 DTV Receiver
Set my box up and there is no channel 5
hi is it not showin the channel it self i had this problem i changed the box on the wall cos my lead wont fit in it and mine workd may not be whats up with yours but ut helped me i rescaned it came on
Jan 04, 2009 | Universal Remote Control 2700A DTV...
Motorola Talkabout T5720 circuit schematic
We are a M dealer and the schematics for the TalkAbout line were never released to the dealer channel.
Jul 13, 2008 | Motorola Talkabout T5720 (7 Channels)...
129 people viewed this question
 Grubhead
Grubhead
