Question about Timex Watches
Cannot re-attach timex watch back cover - Timex Watches
  • Anonymous Dec 17, 2008
    timex watch back problem. I cannot re-attach the back cover.
  • 111 Answers
Good morning ! you need a pressing tools device to put back the case back of you timex watch! thanks ! god bless !.....
Posted on Sep 04, 2008
Yoy need bottom holder and top locator one pressing jig. you take a watch and place on bottom locator and place the back cover on to watch cases then give the load slightly it will fix properly.
Posted on Nov 27, 2008
escapement
  • 2334 Answers
SOURCE: timex watch cover replacment
Align the caseback exactly as it was before you opened it. Make sure thet the groove for stem is in correct position. Lay the napkin on the flat table surface, put the watch on it (dial down) and using both hands and your body weight push the caseback down back in place. Remember: the side of the caseback wich first came out must be last pushed in.
Do not use very soft napkin (towel) as this can brake the glass under the pressure.
If all above described DO NOT work, then there is not enough power in your hands or not enough weight in your body and you will need watchmakers help (he/she will be using special watch press to close the watch).
P.S. Do not get upset if you can not close it; I'm very expierenced watchmaker and very often came across the watches wich I was not able to close without the watch press (even my arms are quite strong and the weight is 95kg).
Do not forget to rate, please.
Posted on Mar 07, 2009
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
I used a modification of the vise solution. I put a plastic bottle screw cap on either side of the watch (bottle side in) and tightened the vise. I heard a satisfying "pop" and I am on my way. Fred
Posted on Oct 07, 2007
escapement
  • 2334 Answers
SOURCE: REMOVE BACK COVER
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
Posted on Mar 23, 2009
  • 110 Answers
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Posted on Dec 06, 2009
How do I set the time on my timex watch?
For Quartz analog timex watch follow the procedure in the attached photo
Mar 10, 2015 | Timex Ironman 30 Lap 53952 Wrist Watch
Alarm does not sound
Thank you for the member's advise that...Replace the back cover with the arrow on the back point directly at the stem. The Indiglo backlight, Alarms and Chimes should all work when all the back cover is in the correct position.
If it's at the wrong position of cover it'll not work correctly because the speaker or buzzer of your watch must be attached on the correct case back. Just try to fix it right!
Mar 11, 2014 | Timex Expedition Digital Compass T40611...
Back has NO screws. How do I easily remove it to replace the two batteries?
Hi, You may know that this watch runs on two batteries, one for digital display and another for analog hands.
If the analog hands stop working all you need to do is to replace the battery and please replace both at the same time since the band and cover take some effort to remove.
You need to take off the both bands first to access the back side than the back cover with a small knife..
Just in case,if you need the user manual here is the link.
Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads .
Take care..
Regards
Jun 14, 2011 | Timex T56381 42 Lap Ironman Triathlon...
How to open a wrist watch
mcdevito75 here, Your Timex may have 4 small screws holding the back onto the watch, if so you"ll need jewelers screwdrivers available on ebay to open the back of your Timex, however this is rare with timex, look for a small tab or a cutout on the back cover that matched the same in the case, if you need to use a magnifier glass available at most Dollar stores or drugstores. Once you find this tab / cutout, use a steak knife under that tab or in that cutout and pry the back cover off the watch, Be firm with the prying but at the same time use care not to hurt your watch or hand.
Jul 27, 2010 | Timex 27191 Wristwatch
Can't get the back of my watch back on
mcdevito75 here, Your Timex watch back cover should have a cutout in the back cover for the stem (winder) make sure this cutout is lined up with the stem the stem lies in this cutout, once you have it lined up, lay the watch down, crystal (glass up on a sturdy surface, Table, counter top etc. Now, with your palm and even, even pressure on the crystal (glass) simply press down, you"ll hare it click shut. Don"t force anything and if you still can"t get your watch back cover on, look for a small watch repair shop in your arear. It may take a special pair of pliers to get the cover on. Most Timex back covers are kind of hard to get back on.
Jul 11, 2010 | Timex 27191 Wristwatch
How do you replace the back cover on a Timex expedition analog wrist watch
mcdevito75 here, Look for any indentations on the back cover and case that should be linned up, as an example, a cutout on the cover for the stem, after the cover is linned up place the watch on a sturdy surface crystal up (glass) and with the palm of your hand apply even down pressure to close the back. If you can"t look for a small watch repair shop, they will close the back cover for you.
Jul 07, 2010 | Timex Expedition 84601 Wristwatch
I had the battery replaced by a watch repair person. The watch is working but the beeps are gone. I don't have the manual and I can't figure out how to reset the beeps. Thanks.
They should have reset (AC) the watch when the battery was replaced. If not you should have them do it for you. You should also be sure the watch is resealed and pressure tested to maintain water resistance.
For manuals you can download from the Timex website. The manual will tell you if/how the chimes turn on and off.
http://assets.timex.com/manuals/?timexBrand=core
Sep 18, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Get cover off the timex watch indiglo w30m watch
Try removing the rubber washer or the black band on the cover then try snapping it back on. I removed the washer and placed it on the back of the watch before I placed the cover on and it just snapped back on.
Sep 14, 2009 | Timex Watches
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Dec 31, 2008 | Timex 27191 Wristwatch
Watches Logo
1,438 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
