Solution: Repair or replace auto-rewind system. Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll. Possible cost: $65-$75
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
If it was just the folding lever part of the rewinder which has broken off then you'll need to use a flat bladed screwdriver or the tip of a knife to lever up the rewind knob sufficiently to pull it up and open the camera.
If you've broken any more than that, then your camera is unrepairable. Spare parts are not available for your camera as it's only designed to last for six rolls of film. Even regular Lomo and Holga models are only intended to last for a maximum of twelve films.
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Usually the automatic rewind starts when the film roll has come to the end. You can rewind also before that by a rewinding button you'll find usually somewhere in the camera body.
To rewind manually, press the film release button (consult the manual if you don't find it) and use the rewinding lever to rewind the film. See this for inspiration: http://www.ehow.com/how_2028878_film-mm-manual-slr-camera.html
If you can wind the film backwards but not forwards, that probably means you've reached the end of the roll. So, time to wind it backwards to rewind the film back into the canister!
film not advancing?
film not rewinding?
film transport motor dead/ needs replaced.
Rewinding but counter not resetting and light meter dead?
Prolly bad connector or ic inside camera = repair shop.
The auto-rewind is triggered when the film advance mechanism detects tension on the film, indicating the end of the roll.
It could be a couple of things causing the problem...
1) The particular roll of film you were using was wound too tight, or has got some moisture in it causing it to stick.
2) If it has done this with various rolls of film, it is likely that the clutch mechanism that detects the film tension is out of adjustment. This is something that a professional camera repair shop will be about to fix for you.
I'm not familiar with this particular model of camera, but there may be a facility to turn off the auto-rewind as a short-term fix.
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
