Question about RIM BlackBerry Pearl 8100
Pearl 8100 I had dropped the phone in water but was quick to remove the battery and do a cleaning ... Now the phone turns on but after the AT&T log appear and the security software process is 100% done a screen appears saying..... UNCAUGHT APPLICATION REGISTRY wait for Oxac3ae 76427d17f19 and Timeout and the icon Ok I try to click on the word OK with my track ball but the keyboard does not function at all. To shoot it down I have to remove the battery. Is ther a way to reset the Pearl via COMPUTER and USB cable ?
  • 561 Answers
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Posted on Jan 14, 2010
My pearl 8100 ball has stuck at "turning radio on" will like to know how to ubstick it?
Try dipping your finger in rubbing alcohol then, applying a little pressure, try to roll the ball around. This issue is common on these phone. Usually the pressure and alcohol help free any debris that may be causing the ball to stick. If that doesn't work the ball may need to be removed to clean out any debris that may be in there. A quick google search can show you how to remove the trackball easily.
Hope that helps.
Sep 19, 2013 | RIM BlackBerry Pearl Flip 8220 Cellular...
Buttons on the blackberry pearl
clear sign of water damage under that button. 8100 is fairly easy to open with a T6 screw driver. then use alcohol to clean the area under that button. you need to also remove the while keypad membrane and clean under it as well
Jun 10, 2009 | RIM BlackBerry Pearl 8100
Dropped Blackberry 8100 in water now wont turn on...
Get some ipa [isopropanol] leave phone submerged in same for a few hours [with battery removed] then remove from ipa, leave for 24 - 48 hrs as long as you can and it should come back to life. All the components in your phone are waterproof so the ipa will eliminate the moisture and should make you happy again.
May 01, 2009 | RIM BlackBerry Pearl 8100
Dropped my phone in water
Remove as many parts as you can such as Battery, SIM Card, Flash Card.Don't charge until the unit has totally dried out. Wrap the unit in towel and shake as much water out as possible. Use a hair dryer on low heat to dry out every part possible. Recharge the battery.
Mar 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Dropped Blackberry 8100- won't come on!!! HELP
it sounds as if your processor has been damaged. as long as there is no physical visable damage to the phone you will be covered under warranty. your phone has a 1 year manufacture warranty. do you have the blackberry destop manager installed on a computer?
for further assistance please email support@ridawreck.com . someone will walk you through the steps to try and recover your information from the phone.
Jan 26, 2009 | RIM BlackBerry Pearl 8100
Screen turned white
Remove the back cover, Remove the battery, if the phone is GSM take the little card out of the back of phone by sliding the metal cover in proper direction. Should be arrows. Put the Sim card back in battery back in then turn phone on. If this doesn't work let me know. Main thing is reseating the sim card. (this assuming you a service provider that requires a sim card. )
Jan 01, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl 8100
Possibly an issue with your internal antenna but the real issue may lie in your coverage area. Check your providers website for coverage maps in your area.
Unplug battery from phone then put back in to see if it helps with the dropped calls.
Aug 13, 2008 | RIM BlackBerry Pearl 8100
Cant hear when someone calls me
I have A Blackberry Pearl I can only hear if I use the head set or speaker any solutions the phone hasn't been dropped, I have taken the battery out and put it back in still cant hear unless I use handset or speaker
Jun 18, 2008 | RIM BlackBerry Pearl 8100
Blackberry 8100, white screen
The same happened to me when I dropped my phone in my briefcase. It actually still had audio, as it rang when calls came in. However, the rest of the phone was useless. You will need to replace the entire unit, unfortunately.
May 22, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
91 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
