Question about Onkyo Audio Players & Recorders
Aplifier Not Working
My amplifier Is burnt out. I've replaced the fuse and as soon as I turn it on the amplifier does not work because the fuse blows out again???.
  • 24 Answers
Sounds like there is a shorted output transistor or two in your amp. Unless you have a DMM that can measure transistor junctions, you probably can't fix this yourself.
Posted on Dec 28, 2008
I haveSamsung HCN4727Wsound stopped working sound amp over heated & C 682 burnt, found same part # cardout of a 42" TV. sound worked picture shady tried p focus I get "no sensor data " please help
So you replaced a Capacitor and an amplifier from what I'm reading here. The part numbers were the same, but were they from the same manufacturer? The capacitors need to be installed in the correct polarity and need to have the correct voltage rating and capacitance. The amplifiers need to have the same pinout, the same voltage ratings, the same power ratings, and the same internal circuitry in order to work.
See if you can get an identical aplifier for the one you are supposed to be replacing. Otherwise you're not going to be able to do an apples to apples comparison.
Nov 02, 2015 | Televison & Video
Signals and break lights wont work, fuse keeps blowing
You have one of them funny american things where it all works backwards so this old gnarled europeon mechanic would have a direct answer like a real proper car,although i do think this is a opel frontier in my language.What i would do here is to disconnect the fancy brake light switch that these motors have and try checking the wires at the back of the vehicle ,like inside the rubber boot from boot door to the bodywork as this is 99% of the problems i get with hatchback type doors or whatever you want to call them in whatever language you call them.Our europeon vehicles have seperate lights for all three functions ,indicators stop and side lights.plus of course the obligatory reverse and fog lights
Dec 19, 2012 | 1992 Geo Tracker
My alpine Mrd-1005 has been best amp ever. But the other day it all of a sudden started blowing fuses on the amp and the current protecter mode kicks on.. as long as I keep volume down in works but as soon...
make sure there is equal amps on the fuse under the hood and at the amp...also make sure to never mount your amp to anything metal....wood only! hope this helps, mine did the same thing
Sep 04, 2011 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
Amplifier only making buzzing sounds
u r amplifires output system is not working properly somthig pcb break problem go to thew mechanic
Apr 05, 2009 | NAD D 3020 Hybrid Digital Amplifier
Radio quit working
does your system have power amplifier aside from your built in amp on radio? if yes, disconnect all supply then put new fuse. try this time, should not blow the fuse. then one by one, connect the supply fo your radio only, if ok, then next is the amplifier, if it blow the fuse, your power amplifier has an issue.
Apr 03, 2009 | 2001 Mitsubishi Eclipse
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
Rockford 1001bd blowing fuses...
It sounds like you've got a short to ground in either your power line or internally in your amp. Either that or the fuse on your amp (usually right on the side) might be blown. Check your power line and make sure that your amp isn't screwed directly to any metal parts of your car, as some amps will short like this. If there's nothing wrong with the power line, send it in for warranty or bring it to your local audio store to have them check it. If you feel comfortable with trying to fix it yourself, then take it apart but be advised that internal screws usually have a glued spot so they can tell if you've disassembled it.
Oct 08, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Amplifier not working
Do yourself a favor and take it to a repair shop. It will be alot easier on yourself and you will get your amp back in working condition alot faster.
May 04, 2007 | AudioBahn A8000V 400W x 1 Car Amplifier...
Blowing fuses
check your car battery and check your ground and check your power wire for any splits or cracks
Nov 22, 2006 | Rockford Fosgate Punch P3002 Car Audio...
80 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
