Question about Garmin Edge 305 GPS Receiver
False Elevation Edge 705
I get a wrong elevation on my Garmin Edge 705, it's been working great for months and all of a sudden it shows the wrong elevation, it shows 1957 mts instead of 1450 which is the correct elevation.
  • Robert Main Jan 03, 2009
    After a long trip to over 2300m the Garmin now reads 1587m when back at sea level
  • Anonymous May 11, 2009
    I encounterd the same problem with my edge 705 after the update from 2.20 to 2.70. Any solutions?
I have exact same problem. It has been working for 5-6 months but suddenly on one trip it now reads app. 280 meters too high elavation
Posted on Feb 28, 2010
GPS elavation
The altimeter requires calibration on the Edge 800.
To calibrate the altimeter:
1. Select MENU > > System > GPS > Set Elevation.
2. Enter the elevation, and select the check box.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Nov 13, 2011 | Garmin Edge 800 GPS-Enabled Cycling...
I have a garmin edge 705. Every week I ride the same course. When I compare the graph of this same course they do not coincide. The starting point elevation is not the same aldo I always start at the same...
The reason is linked to startup of the device probably. I have same issue.
2 ways to improve :
1/ Startup your device
You need to startup device, and wait automatic change of the screen to the ride mode, from the sattellite search screen.
You also can check you have more than 4 sattellites before starting a ride. Altitude can only be computed when at least 4 sattellites are synchronized. So start your device in the open air, not indoor, nor close to a building.
Garmin devices start automatically and have probably a smoothing function that make altitude converge to the reality slowly from a started erroneous capture.
2/ Upload your ride on Garmin connect site, then apply altitude fix algorithm proposed. This algorithm will fix the altitude of your waypoints, both fixing pure altitude start issue, and also fixing denivellation computation, which is erroneous because of cumulation of errors.
Hope this helps
Apr 12, 2010 | Garmin EDGE 705
There is no "climb data", elevation gain when I download to Ascent software.
Hello. you may need to go to garmin.com/drivers and download a new driver into your computer before you use that software again. Joe
Mar 22, 2010 | Cadence Garmin Edge 705 Bundle [heart,...
My garmin edge 305 freezes up during the ride on occasion. the distance and elevation numbers just stop changing, while I'm still riding. thanks
OK, There is a battery problem where the contacts become loose within the unit, i opened mine and followed the instructions i got on this site...MTB gurublog If you decide to do so..however if the 305 is in warranty contact garmin.com and ask for new unit... they accept the problem is widespread.
Nov 01, 2009 | Garmin Edge 305 GPS Receiver
Total elevation gain consistently way too high (20+ percent)
I have the same garmin, and have the same problem.
The high changes even during flat runs so when added you have this overamount of climbing.
I just reduce the points of the track and then the addition is more accurate.
My problem now is that the GPS stops working during runs (turns itself off). Awful!!!
Aug 03, 2009 | Garmin Edge 205 GPS Receiver
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
May 12, 2009 | Garmin EDGE 705
False elevation reading with garmin edge 305
perform a software download from Garmin.com by logging onto the site and downloading the webupdater
Aug 23, 2008 | Garmin Edge 305 GPS Receiver
305 Elevation Problem
Sorry to have to break (no pun intended) this to you, but I have had two units do this. Once this problem starts eventually the Elevation field will display and stay at 65616. The problem is with the barometric altimeter and cannot be fixed without sending the unit to Garmin. When you call Garmin technical support, they will have you do all sorts of resets - be patient - eventually they will concede that the unit is busted and give you an RMA. Both times this happened was after the unit got a little roughed up (one time dropped it, the other time was mountain bike tumble) - evidently the altimeter is the least robust part. Good luck.
Jul 28, 2008 | Garmin Edge 305 GPS Receiver
Elevation Problem
Some models have the Barometric Altimeter which needs to be calibrated, and some units do not.
Vertical Accuracy of a properly calibrated Barometric Altimeter is +/- 10'. If you have a unit that uses provides a GPS Elevation only, a +/- 50' vertical solution is pretty standard.
Jun 22, 2008 | Garmin eTrex GPS Receiver
Wrong elevation showing garmin etrex vista
Found a fix, by resetting all user data my problem was fixed.
Garmin Edge 305 Power off device and hold 'mode + power'
eTrex Vista Power off device and then hold 'page + enter + power'
Hope this helps!
Dec 16, 2007 | GPS
Garmin Edge 305 GPS Receiver Logo
883 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
