Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon pixma 170
Error 6900 alarm flashing
SOURCE: ERROR 5010
solucion a email stnilton@hotmail.com the error 5010
Posted on Mar 28, 2008
  • 412 Answers
SOURCE: my canon pixma mp140 error 2 and the alarm light
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Mar 09, 2009
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
pineworks
  • 4041 Answers
SOURCE: how do I empty the Canon Pixma waste ink (Pixma
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Please if you happy call back and gave a vote
Posted on Feb 13, 2010
Testimonial: "Thanks very much, that was very helpful and it worked."
  • 518 Answers
SOURCE: service error 6000 canon pixma
in the book at the back is normaly the error codes
Posted on Jul 06, 2010
Canon pixma mx870 error B200
how to repair b200 error code on canon MX870 printer?
Sep 20, 2012 | Canon PIXMA MX870 Wireless Office...
Waste full in pixma 170 flashing alarm what to do buy always crtridges
. Hold RESUME then press & hold POWER
2. Release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 31, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Nov 27, 2008 | Canon Office Equipment & Supplies
Canon printer pixma ip6220D is showing error code 9000 alarm light flashing. What to do please?
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
Dec 21, 2007 | Canon PIXMA iP6220D InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
113 people viewed this question
old marine
old marine
