Thats too much of a coincidence. Did you check the power from the wall using a meter yet?
Do they both power on with no reception, or no power at all?
Also, are they in the same room, same vicinity, or different rooms, and do you have cable, satelite, or just local air channels?
I think that bear is on the right track. If both lost power, you might check the breaker box for the house. You may have had an overload and flipped a breaker. Two at the same time is quite the coincident.
Power supply failure due to moisture.try to get it repaired as it would be very costly.think before reparing
think twice before getting it repaired
pls do rate the solution
thanks.
regards.
fixya expert team
Hi I have two tv's and they both broke down today at the same time. There was no burning smell from them. Non of my neighbours had any problems. What could be the problem.It cant be dampness because the two tv were on and they both died.
We pluged in a different tv and it worked
