Question about Philips CDR760 CD Player
Cd recorder problem
Hi have got a philips cd recorder which i bought secondhand, unit will play perfectly but will not record, please help!!!!! mark
My Phillips 775 CD recorder will now only record with Maxell CD-R Music Pro brand discs. They might still be availabvle at Wal-Mart - they are usually in a bulk pack and are in full-size jewel cases. Don't know if that'll solve your problem. If you buy that brand of discs and they don't help, I'll buy them from you...
Posted on Sep 05, 2008
My 760 recorder keeps show no audio when I try to record. I've tried hooking it up serval ways no luck. However it plays perfect.
You can not use normal Data CDs. Use CD-R Digital Audio CDs or CD-R Audio recordable CDs. If you use correct Digital Audio Recordable CDs, it will show OPC. Once you press Recording, audio out is coming. Otherwise you can not listing to audio. Please read manual carefully. Above will solve your matter.
From Channa
May 10, 2011 | Philips CDR760 CD Player
Have just purchased a secondhand Philips 570 cd recorder and purchased TDK blanks for my first recording test.While the disc was still in the machine it recorded and played back ok.However,after removing...
Are you sure the TDK blank had either AUDIO/MUSIC somewhere written on the disc...if not, then that is the problem. On the other hand it it should not have recorded or played back as you said it did.
If it did have Audio/Music written on the disc, then first of all give the laser a clean by using either a disc cleaner or better still, take the cover off and gain access to the laser, using a cotton bud, diped in INDUSTRIAL METHALATED SPIRIT (usually coloured purple) do not use medical metholated spirit as oily additives could be added and smear the laser lens. Dry off the lens with the dry end of the cotton bud. Do not soak the cotton bud in the spirit, just a very small amount will do !!!
If it does not work now, try using other good named branded Audio/Music CD-R discs as there appears to be such a variation in the quality of CD discs which is well documented !
Did you FINALISE the TDK disc before you removed it from you recorder??
I have a feeling its the TDK disk.....I avoid TDK if I can...Try Sony or Philips Audio/Music discs, very few failures for me with those brands.
Hope this has ben of some help...good luck
Sep 12, 2010 | Philips CDR870 CD Recorder
It is not recording. I press play then I record. When I am finished I press stop. I then press finalize then record. But it does not record. Am I following the proper recording sequence?
Don't you have the manual?
http://download.p4c.philips.com/files/c/cdr870_17/cdr870_17_dfu_eng.pdf
Press REC and the RECORD indicator will start flashing when the unit is ready to record. You can set your levels for an analog input by playing it while in this mode.
When your source is ready and you have your levels set up, press PLAY on both units.
If you don't see the time incrementing , it's just standing still.
Apr 20, 2010 | Philips CDR870 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
Cd's wont play
can you please post here the model and the part # of the cd player.. & please kindly inform me the type of cd she play in the unit, is it a Audio CD..?
Thanks..
Apr 16, 2008 | Audio Players & Recorders
Phillips cdr 950 audio cd recorder
Hi Averil
Get yourself a copy of the manual directly from the Philips website (look on the left of the screen for all the relevant links)
Your CD recorder has a 2 pairs of phono (rca) sockets on the back.
Connect your keyboard's output (line out ideally or headphones if there isn't a line-out) to the inputs on the back of your CD recorder. And connect the outputs from the CD recorder to your amplifier. If you don't have an amp, you can plug headphones into the CD recorder so you can hear what you're playing.
Good luck! Let me know how you get on with it.
Jan 10, 2008 | Philips CDR785 3-Disc CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Open Questions:
Philips CDR760 CD Player Logo
275 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
