Question about Toshiba PDR-M3 Digital Camera
Dark playback image
The playback image is too dark even though I used the flash.
    Novelist:
    Scholar:
  • 104 Answers
It could be that the subject is too far away. so just Move closer to the subject.
Posted on Sep 15, 2005
SOURCE:
Dark images
your imager is going bad. need to send in to canon usually flat rate applies. worth the money to fix
Jul 07, 2009 | Cameras
Dark image when taking pictures of sceneries
If the pictures show up normal on the computer then the back light for the LCD is going bad...
try to replace the back light..
thank u
rate me!!
May 24, 2009 | Canon PowerShot A550 Digital Camera
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Nikon D40 Image Darkness
You probably have "bracketing" turned on. In your menu settings, search for bracketing and make sure it is off.
Feb 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Video Images at Night Playback Dark
Buy yourself some studio lighting
Sep 16, 2007 | Sony DSC-T7 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
The problem here is likely the auto setting. Put it to sunny, clear day instead of indoor picture and you should be ok. Also, point it at neutral colored objects when you take the picture and allow it time to adjust by holding the button in partway before depressing it fully.
Jul 26, 2007 | Canon PowerShot A630 Digital Camera
Why do some images recorded with flash come out looking a little dark?
Recording a subject that is outside the flash range can cause the subject to appear dark in the resulting image, because not enough of the flash reaches the subject. When this happens, you can use flash assist to correct the brightness of the recorded subject, so it appears as if the flash illumination was sufficient. Note, however, that recording certain types of subjects may not produce the results you expect, even if you use flash assist.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Toshiba PDR-M3 Digital Camera Logo
24 people viewed this question
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
