Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Drier Hi my washer works perfectly but i had no user manual and i,m not sure what the dial has to be turned to to use the drier. i tried one thing but water started filling the machine. Not sure how to use the drier on its own
    Sergeant:
    Champion:
  • 223 Answers
Dont know if it will help try this website: www.bshappliancecare.com. I think Bosch and Siemens might have some common ground but please please dont hold me to this.
Posted on Sep 26, 2008
How do I troubleshoot if My kenmore washing machine fills with water and then stops
It is more than likely the lid switch. Most modern machines will fill with water and then wait for the lid switch. If it is bad they will just sit there.
Jun 27, 2014 | Kenmore 22422 Top Load Washer
I need a user manual for my White Knight Washer Drier
Try this PDF this seems to be for the 77AW by White Knight!
Jun 24, 2012 | Washing Machines
Washer filled with water then stopped working, still full of water. Drier works just fine. Happened durring an electrical short in my house, but the fuse that was blown was not linked to the same part of...
You state you had a short in the home. Since the washer is on 110V system, you can try a different outlet and see if the machine works. Although you state that it isn't on the same part of the panel as the washer/dryer, and the dryer works, the dryer is on a different breaker, and it may indeed have had some effect on the panel that hooks to the washer. Try my first option, and let me know how you make out. I believe you'll find that to be the trouble
Joe
Sep 07, 2011 | Frigidaire FEX831CS Top Load Stacked...
Sometimes the washer randomly beeps continuously until i unplug it what do i need to do. I'm sure that it is a code i just do not have a manual for the washer and drier.
You did not mention what model you have..THIS INFO IS VERY IMPORTANT FOR A CORRECT DIAGNOSIS If it just happens to be a Oasis washer it needs a new user interface panel have seen this concern often if it's a different model it my still need a interface panel but the type and model number takes out the guess work......
Dec 21, 2010 | Kenmore Washing Machines
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
I would like a manual for an IWDE7145 washer/drier
You can try diplodocs.com. This may have what you need. If not, it has links to other sources to find one.
Hope this helps you.
Oct 28, 2009 | Washing Machines
Zanussi Washer Drier
We had same problem with same model machine - basically you have to ignore the letters behind the see through plastic window and write new ones around the dial with a permanent marker that you know are correct and correspond to what you want. It's a lot of trial and error - try and go for the simple dryer function first and mark write the corresponding letter against the dial straight away, then work out the distance between each letter on the proper dial and and you should replicate these distances and letters with your pen.
Jun 30, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
231 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
