Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Lowering Brushes How are the brushes lowered?
In the front where the watwer sucks up there is a hairball how do I get the front plastic cover off
Posted on Sep 21, 2008
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
Spin brushes not turning
Most all Hoover SteamVacs rely on a turbine to create suction and spin the brushes. The brush block (removable, just clips in) will have one of the 5 or 6 brushes with a stem inserted up and in the turbine. Hoover did a poor job sealing the hole that stem goes through and water and cleaner seep up to the lower bearing on the turbine and the bearing siezes. The turbine has a gear assembly inside! It is not easy to replace the turbine, especially the first time because what needs to be removed can be a head scratcher. However goes easier the second time. The turbine can be taken apart once out and I have used light grease to free up the bearing and gears but it's only a temporary fix. Different models have different part # turbines so pay attention when ordering the part. Need a work bench environment to do this. On occasion the brush block itself can get stuck because the brushes gear mesh together and the stemed brush drives them all. They can and do bind up with junk and do wear down and bind. If you can't turn all 5 or 6 brushes by spinning with your fingers on the stem, the block itself could need replacing. The block and brushes do come apart for cleaning but be careful because they are plastic clips on both halves of cover/retainer and can break.
Sep 16, 2013 | Hoover SteamVac F5914-900 SpinScrub...
Steam-it floor head brushes
my guess is probley used for low carpets or kinda like a dirt pusher just for a add on just for looks
Oct 17, 2012 | Oreck steam-it Stick Vacuum
Henry brushes seem to catch in the carpet when pulling-will the brushes soften and make it easier to use as it makes the head bounce of the floor a bit when pulling making it harder work to vacuum?
There is a "see-saw" type switch on top of the cleaning head (the part that you push across the floor). This raises and lowers the brushes according to the type of floor you are vacuuming. Move this switch to the other postion and you will find that it runs over the carpet more smoothly.
Nov 05, 2010 | Henry Vacuums
BRUHES WON'T ROTATE
The brushes are operated by suction from the motor. Most of the problems with these models are in the turbine, it just needs to be serviced, some replaced. You can check the filter under the bottom (a red or white pull tab). Also check the lid on the lower tank to on properly.
Apr 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Where can I get motor brushes for an Epic 6500 SR
You can get these brushes at and AERUS ELECTROLUX repair center. However be aware this is a hi rpm motor.
Unlike lower output, heavy duty motrs from 40 years ago, BRUSHES CAN SELDOM BE REPLACED ON THEIR OWN. IF YOU CAN ACTUALLY GET ALL THE WAY IN AND OUT OF THIS VAC , THEN YOU ARE CAPABLE OF THE MOTOR WORK AS WELL.
Once the motor is removed from its housing be sure to inspect the commutator surface for gapping between the segments, the lines must be parallel nor should the com show apple core shaped wear. Either one will negate new brushes.
New brushes are best seated with a fine abrasive commutator stone and run in at half speed & half voltage to allow them to gradually seat, especially on a hi RPM motor.
Post back if you need help. Good effort !!!!
Oct 10, 2009 | Electrolux Epic 6500 Vacuum
Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
Apr 11, 2009 | Kirby G6 Bagged Upright Vacuum
Brushes not turning on 8920 2x Bissell
Brushes are switched on by lowering the handle which activates a micro-switch located inside the lower part of the machine. Vacuum must be running as well. The DC power for the brush motor comes from a Bridge rectifier located on the PC board located in the handle. I have drawings that might help you.
petedcurtis@gmail.com
Nov 26, 2008 | Bissell 8910 ProHeat Clear View Upright...
Brushes not contacting floor
It is unlikely that you have worn the brushes to the point that they no longer contact the floor properly unless you use it daily and have a very rough tile or concrete floor and even then they should outlast the machine. It is more likely that there is a problem with the switch that moves them up and down for different floor settings. Also remember that the brushes will be up while the unit is in the upright position no matter what the switch is set to only when you bring the handle down in the operating position do the brushes lower to contact the floor. Pull the brushes out and check to see nothing is interfering with the operation of the brush adjustment or for any broken parts. As for the squeegee they do get deformed and this will prevent the unit for sucking up the water properly so it should be replaced if needed. For any parts visit www.stevessewandvac.com if you don't see what you need listed email them someone can help.
Aug 13, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
