Question about Fujitsu ScanSnap Manager
CAN NOT DRAG THE DOC SCANNED TO THE FOLDER
MY SCANSNAP COLOR IMAGE WILL NOT LET ME DRAG THE DOC TO THE FOLDER
Normally only the left mouse button works for dragging PDF file from one ScanSnap Organizer folder to another.
If the left mouse button will not drag the files to another folder, try the right mouse button. If the right mouse button is the only one that works, you have your left and right mouse buttons reversed (see the Mouse settings under the Windows Control Panal).
Eric
Posted on Oct 20, 2008
How to recreate a new folder for my scansnap manager to be able to scan. I tried without success. Where do I put it, etc.
Right click on your desktop. Choose new and then folder. Name it Scansnsp And it's done. When you setup your scanning be sure to tell it to send your scans to the desktop folder named scansnap. I hope that helps
Mar 31, 2017 | Computers & Internet
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Scansnap hardware error 0x00048004
I had this exact same problem. Turned out that I was using the wrong power adapter. Enough power to turn on the scanner lights and connect to the computer, but not enough to actually perform a scan. As soon as I realized I was using the wrong power cord, I switched it up and voila!
Jan 23, 2013 | Fujitsu ScanSnap Manager
When I try to scan, I get "Undefined error occurred (0x80004005). A probable cause is that the system is unstable. Reboot the system. If this does not resolve the problem, contact the store where you...
I just fixed it. Uninstall the application by choosing applications and finding scansnap. Drag the folder to the trash. power down your scanner and unplug the USB. Go to the Fujitsu website and download the software again and reinstall it. Plug in the power and USB into your scanner and everything should work fine.
Jul 03, 2011 | Fujitsu ScanSnap Manager
I get a message when i try to scan that says "not
Hi Good day!!! try to change your save target folder of your fujitsu. make a new folder in your "my documents" name it your desire folder name. and then after making folder open your ScanSnap manager and then go to "SAVE tab" and then click browse locate your folder that you make earlier and then click apply. and then ok.
reply to me if you have any concern i will assists you more..
Thank you for using FixYa
Please accept if my solution helps you
Nov 17, 2010 | Fujitsu ScanSnap Manager
Scanner will not pull the paper all the way through & scan. Scanner says not valid folder to save image is selected . Set the save folder for the scanned image data. I don't know what to do
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select “Scan Button Settings” from the Right-Click Menu.
2344c41.jpg Select the “Use Quick Menu” check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the “scan” button on the ScanSnap.
Click the “Scan to folder” icon in the quick menu when scanning is completed.
The “Scan to Folder” dialog box appears.
Check the scanned image in the “Scan to Folder” dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu ScanSnap Manager
I can not scan to folder now, I am using scansnap s510m, please guide how to solve this problem. I am using macbookpro
Click and hold down the mouse button over the ScanSnap Manager Icon in the Dock menu and confirm that Quick Menu is checked.
load the document you want to scan
press the scan button
when scanning is complete the snapscan quick menu appears
place the curser on the scan2 folder
click it in the action list
a preview window appears
You can change the file name and the folder you want to put it in. You can also resize it here by dragging the lower right corner
here is the manual
http://www.fujitsu.ca/pdf/scanners/manual/operator/s510/S510M_Owner_P3PC-1942-01ENZ0.pdf
Dec 31, 2009 | Fujitsu ScanSnap Manager
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
Scan Snap - color/balck & white
You don't need to scan the doc again. If you have a graphics editing program (like Photoshop) you can change the mode to Grayscale and resave it. I bet you by now you probably have rescanned it anyway :)
Jul 28, 2008 | Fujitsu ScanSnap Manager
Computers & Internet Logo
87 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
