I also encountered that, even though installed it did not work, i also tried restarting my computer desktop and printer did not work, I also tried removing the usb connector and returning it back...................................This is my solution, i tried another usb connector and it. hope work on you too.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels. Thank you for using Fixya
Activate head cleaning before a test is taken . If not detected please contact service.
Not sure if your answer is correct, As I said Windows update thought it was downloading the correct driver and it didn't work correctly. I don;t want to say your link isn't helpfull, But I followed another suggestion and installed the Windows Vista Suite for the Brother MFC-5840CN all in one.and it not only fixed the problem it also installed all the multifunction drivers and software.So I am good for now. Thank you for responding to my delema. In case someone else needs it, Here it is.
According to your problem first check that you have installed the driver properly or reinstall the driver. Check the USB cable of the printer. Replace the cable. Turn the printer off before installing the driver. Turn it on again while the driver installation wizard will ask to connect the printer. After installation reboot the printer and system both.
