Question about Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
  • Anonymous Mar 16, 2014
    fridgidaire dryer not drying clothes
We have a fridgidaire gas dryer model # GLGR642AS2 is not drying cloths. The gas ingites but doen't stay lit. We have taken the dryer apart and cleaned out lint through out the dryer and ventilation. Our cloths take at least 5 hours to dry.
Thanks.
Chad
Posted on Oct 12, 2008
  • 706 Answers
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Posted on Sep 04, 2008
I have an LG gas dryer only 7yrs old. Some loads are coming out still soaked after the cycle has finished. I've looked through the back of the unit and the flame is igniting. However, I have noticed that...
i am not a dryer expert,so i can only make these suggestions.
1.make sure the lint filter is very clean.
2.make sure the dryer is sitting level on the floor.(if it isn't sitting straight on the floor,the clothes may not be touching the sensors,causing the heat to turn on & off while drying.
3 do not overload the dryer with wet clothes.
4.pick the right heat setting for the amount & type of clothes.
Mar 30, 2015 | LG Dryers
How do i use the drying cycle of the hotpointWD420 model. My clothes come out soaking wet. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 19, 2011 | Hotpoint Dryers
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
LGR5636kq0 model. not drying clothes reasonable time
It could be the tumbler. Also check the vent coming from the back of the dryer (make sure it is not clogged)
Nov 10, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
If clothes are wet then no heat. if clothes kinda dry then heat at first then no heat
Hello Friend, If the burner on your gas dryer is igniting the first few times producing heat in the early part of the drying cycle and then Doesn't ignite the remainder of your drying cycle, It's pretty safe to say that you need to replace the valve coils. Here's general information pertaining to the replacement of your valve coils: Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks!
Jun 27, 2009 | Kenmore Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
My dryer isn't drying my clothes!
soundsmore like a coil kit thats gone bad,located atop the gas valve assy istelf, part number 279834 retails for about $20
Nov 09, 2008 | Crosley CDG6000 Gas Dryer
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 | Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
193 people viewed this question
Top Dryers Experts
