Question about Konica Minolta DiMAGE 7i Digital Camera
What is the direct manual focus (DMF)? - Konica Minolta DiMAGE 7i Digital Camera
    Master:
  • 425 Answers
With DMF function selected, focus can be manually changed after it has been once confirmed using camera's AF system. DMF cannot be used during continuous advance.
Posted on Sep 15, 2005
SOURCE:
I have 2014 1.6 shortage do s it have dmf as the clutch is slipping
typically when a clutch slips it is either worn out or has oil on the friction surfaces from a leaking main seal. no idea what dmf is either???
Nov 05, 2017 | Cars & Trucks
Ford ranger 30 tdci i changed dmf now vehicle starts then cuts out straight away any advice
I would suggest that you take this to an honest Ford dealership to get this looked at. I am unsure what all needs to be done to get this sorted out.
Jun 02, 2016 | Ford Ranger Cars & Trucks
How can I stop the metering on a Sony a77 Camera?
When you are using non brand lenses, with an adapter ring, most camera's can't communicate, so you have to use the lens as a non chip lens and it only will work in full manual mode. So switch the camera to M (manual) and then do manual focus and manual aperture on the lens. When you shoot a picture, look on the histogram if you need a faster or slower shutter speed and dial in the speed (manual) you think is correct.
Jan 12, 2015 | Sony a77II Alpha 77 Mark II Translucent...
The manual focus ring on my camera doesn't work. The ring turns but does not seem to adjust the focus. Automated focusing still works. How to fix it?
Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
Jan 31, 2011 | Konica Minolta DiMAGE A2 Digital Camera
Lg kp500 themes!
Hmm der's no way of applying themes to KP500. the 2 ways 2 apply themes are ".dmf" and ".swf"...... .dmf way of approahing is more preferrable than .swf......
May 07, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Cannot load *.dwz files into Ulead DVD MovieFactory 6
Can't start any new or existing projects at all. Nothing happen
Jan 26, 2008 | Ulead DVD MovieFactory for PC
What is the Direct Manual Focus (DMF)?
With DMF function selected, focus can be manually adjusted after it has been once confirmed using camera's AF system. It is useful for Macro photography and Portrait photography. DMF cannot be used in continuous AF mode.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What is Flex Digital Magnifier?
When using manual focus(MF) and direct manual focus(DMF) mode, Flex Digital magnifier (FDM) can be used to confirm selected flex focus point by enlarging it to 4x. The focus point can be selected after enlarging.
With DMF function selected, focus can be manually changed after it has been once confirmed using camera's AF system. It is useful for Macro photography and Portrait photography. DMF cannot be used in continuous AF mode.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
When using manual focus(MF) and direct manual focus(DMF) mode, Flex Digital magnifier (FDM) can be used to confirm selected flex focus point by enlarging it to 3.3x. Also the focus point can be selected after enlarging. (The conventional models: Magnified 2x, at the center of the LCD.)
Open Questions:
Konica Minolta Dimage 7 delay in start up and shot down procedure Hi, I have a Minolta Dimage 7 Digital Camera SN91202050. I'm very keen in electronics and I have its service manual (45 pages). Few months ago, I upgraded the firmware to ver 2.01e. (I read the full compatebility notice before installing). The camera worked so fine. I've got about 2000 jpgs And the last day I took about 200 jpgs in a very short period of time. So I was enforced to exchange the batteries during the snapshots. I'm using 2500mAh MiMH Kodak batteries. I noticed that the grey front right hand part of the camera is a little bit overheated. The next day, and after the camera returned to its normal temperature, I tried turning the Main Switch/ Mode Dial from OFF to Recording Mode, after putting a completely charged batteries. Unfortunately, I heard a small sound "Tick" then nothing happened else, the Data panel stayed dim(unlit) and with no data, and no red indicator had seen, also the monitor LCD didn't start. I didn't hear the noises which the camera should give in normal conditions. I left the switch as is, few minutes later, the camera continued the startup procedure, as I heard the noises and the Data panel lit in green and it displayed the normal status. I made several snapshots and everything were going well. I turned the **** to playback mode, I have seen the entire snapshots I did. Which mean tha the CF card is working well. Also all the other knobs were working properly. Then I decided to turn the camera OFF. Again, the LCD monitor turned OFF directly, but the upper Data Panel was left ON!!! And I heard "tick" Few minutes later, it turned OFF automatically. And I heard the same noises in the normal manner. 1-Does that mean the main board had a cold welding point? Or, the board was affected in the earlier overheating. I tried to use the transformer instead of the internal batteries, and I found this same situation. Delay in the turn on and turn off. And also the delay period is the same. 2-Does that mean that some chemical capacitors were damaged? ( wich capacitor should I replace?). 3- Does that mean there is a cold welding in some points beyond the processor in the MAIN PCB ASSY(0402) due to the frequent humidity and overheating? N.B I tested the internal backup battery, and it gave 3.24V (it's ok) Kind Regards, Soubhi Sabbagh Email: s.sabagh@aloola.sy
Mar 13, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Konica Minolta DiMAGE 7i Digital Camera Logo
205 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
