Question about Konica Minolta DiMAGE 7i Digital Camera
Is the focus area switchable? - Konica Minolta DiMAGE 7i Digital Camera
    Master:
  • 425 Answers
The focus area can be set for Wide Focus Area, or Spot Focus Point. When using the Spot Focus Point, the DiMAGE 7i offers "Flex Focus Point (FFP) " for controlling the position of the Spot Focus Point. This is a powerful tool for off-center subjects.
Posted on Sep 15, 2005
SOURCE:
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
I need to change my power supply from 110 volt to 230 volts on my ASUS model A-45GA and can't find a switch
Must not be a switchable power supply then. You will have to exchange for one that is switchable. Not all p/s have dual voltage capabilities.
Aug 22, 2013 | AMD ASUS A7N8X-VM/400 nForce2 IGP...
AF Area means what
Auto-Focus Area. It specifies which area of the image the camera uses to focus.
Jun 16, 2011 | Casio Cameras
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
When switching on camera. pictures turn pink. why
ia mode or not?
is it out of warranty? I noticed that the manual was from 2005.
http://service.us.panasonic.com/OPERMANPDF/DMWAC5.PDF
The manual doesn't mention any pink area of focus.
I do not know why the area in focus is pink. That's the first time I heard someone complain about that on any digital camera.
Good luck on this repair.
Jul 23, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Wrong icon when selecting dynamic area
The D40 Dynamic area focus starts on the centre AF area then moves the focus to follow the subject.
The camera has followed something to the right and selected the right focus area.
This is normal.
You could select Single Area in the menu and move the area back to the middle using the rear AF Sensor Selector.
Jul 05, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
I installed an aftermarket radio in my 2003 ford expedition and my amp won't power up nor will my rear sub woofer play.
Do you have a battery positive wire as well as a switchable power wire? Is it properly grounded? Double check for power and ground. Aftermarket radios have two blue wires for switchable power. one for an amp, and the other for a power antenna. Make sure the right one is used.
Jul 01, 2009 | 2003 Ford Expedition
Switchable RF input
Press the channel selection switches at the same time until RF03 or RF04 display. Select the correct channel by pressing the UP ch. button.
Dec 11, 2007 | GoVideo VR4940 DVD Player/VCR
The focus area can be set for Wide Focus Area or Spot Focus Point. When selecting the Spot Focus Point, the DiMAGE A1 can be set "Flex Focus Point (FFP) ".
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Focus malfunction
THere is a little switch on the back of the camera, just under the area selection Dpad. Make sure it is not in the 'L' setting. This locks the selected autofocus area.
Sep 14, 2005 | Nikon D70 Digital Camera
Open Questions:
Konica Minolta Dimage 7 delay in start up and shot down procedure Hi, I have a Minolta Dimage 7 Digital Camera SN91202050. I'm very keen in electronics and I have its service manual (45 pages). Few months ago, I upgraded the firmware to ver 2.01e. (I read the full compatebility notice before installing). The camera worked so fine. I've got about 2000 jpgs And the last day I took about 200 jpgs in a very short period of time. So I was enforced to exchange the batteries during the snapshots. I'm using 2500mAh MiMH Kodak batteries. I noticed that the grey front right hand part of the camera is a little bit overheated. The next day, and after the camera returned to its normal temperature, I tried turning the Main Switch/ Mode Dial from OFF to Recording Mode, after putting a completely charged batteries. Unfortunately, I heard a small sound "Tick" then nothing happened else, the Data panel stayed dim(unlit) and with no data, and no red indicator had seen, also the monitor LCD didn't start. I didn't hear the noises which the camera should give in normal conditions. I left the switch as is, few minutes later, the camera continued the startup procedure, as I heard the noises and the Data panel lit in green and it displayed the normal status. I made several snapshots and everything were going well. I turned the **** to playback mode, I have seen the entire snapshots I did. Which mean tha the CF card is working well. Also all the other knobs were working properly. Then I decided to turn the camera OFF. Again, the LCD monitor turned OFF directly, but the upper Data Panel was left ON!!! And I heard "tick" Few minutes later, it turned OFF automatically. And I heard the same noises in the normal manner. 1-Does that mean the main board had a cold welding point? Or, the board was affected in the earlier overheating. I tried to use the transformer instead of the internal batteries, and I found this same situation. Delay in the turn on and turn off. And also the delay period is the same. 2-Does that mean that some chemical capacitors were damaged? ( wich capacitor should I replace?). 3- Does that mean there is a cold welding in some points beyond the processor in the MAIN PCB ASSY(0402) due to the frequent humidity and overheating? N.B I tested the internal backup battery, and it gave 3.24V (it's ok) Kind Regards, Soubhi Sabbagh Email: s.sabagh@aloola.sy
Mar 13, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Konica Minolta DiMAGE 7i Digital Camera Logo
168 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
