Question about Toshiba PDR-M3 Digital Camera
Battery my Battery runs out quickly. why?
    Novelist:
    Scholar:
  • 104 Answers
There could be few reasons for that: 1. You are using the camera in extremely cold conditions - Put the battery in your pocket or another warm place to heat it and then load it into the cameras just before taking a picture. 2. The terminals are soiled - Wipe the battery terminals with a clean, dry cloth. 3. The battery has reached it's effective life - Load a new fully charged battery.
Posted on Sep 15, 2005
2006 Accent acts like the battery is dead every few days and will not engage the starter. a meter on the battery shows it at 12.6 volts. Starts if we jump it. Why?
check battery voltage while under load, with head lamps on for example and note voltage and how quickly it drops, if it drops fairly quickly I'd say battery is faulty, also check voltage with engine running to make sure alternator is charging, should be 13 to 14.5 volts with motor running
Dec 05, 2016 | Cars & Trucks
What does it mean when my kindle fire hd gets too hot after a few minutes of using it?
Do you notice your battery draining quickly? When your battery drains quickly, it heats up. This can happen if you are running many things at once, or if your battery is getting old.
Jul 09, 2014 | Amazon Kindle Wireless Reading Device
Jazzy power chair's battery runs out quickly afert being fully charged
I had the same problem I had to replace the batteries problem solved.But the batteries are not cheap
Apr 01, 2013 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Why does the battery run down so fast????
CRV3 Lithium.
These type of batteries run out quickly, because they are basically just 2x AA Rechargable tapped together. Cameras using these kind or just AA batteries run out quickly and don't last so long. Its always on and running as long as the connectors are touching (Positive and Negative) conductors.
Resolution:
Take out the batteries when not in use
If you have the budget, buy a new camera; stay away from these type of battery cameras
-Price ranges from 100USD-1,000+USD
Good luck, and rate my response.
Dec 16, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
My sons razor e200 dies quickly. I have changed the batteries, brought a new charger. I have checked the connectors and the tires are not flat The light is green but after 25 yds, turns and says needs to...
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Aug 15, 2010 | Razor E200/300 Electric Scooter Battery
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Camera battery seems to run out of charge quickly
It sounds like your battery is dead. If you get a replacement battery, it should solve both problems.
Jan 25, 2009 | Kodak EasyShare M1033 Digital Camera
Battery runs low very quickly
my computer battery runs low very quick what can be the cause of this
Dec 11, 2008 | Sony NW-A1000 MP3 Player
Battery runs down quickly
check the battery and look for a sticker on the back, it should pink poka dotted, if its completely pink, it means it got wet.
if it got wet, thats the answer to ur problem
Jun 26, 2008 | LG VX8300 Cellular Phone
Toshiba PDR-M3 Digital Camera Logo
35 people viewed this question
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Simon Flummox
Simon Flummox
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
