Question about Palm LifeDrive Handheld
PalmOne LifeDrive OS Installation
Before buying the PalmOne LifeDrive, it have the OS of "Palm OS 5.4 (Garnet)." I'd like to know if I can install Pocket PC as an OS to it, instead of the one they provide to it. Can I install it? Thanks
  • 44 Answers
Palm os is a flash rom built into the device, the only way your going to be able to do this (which will risk the device itself and i highly recommend NOT doing) is if you can get your hands on a flash tool to flash the ROM with your version of pocket pc os. i have never seen it done, but there are rumors that a palm treo 670 has windows mobile 2003SE on it. i just wouldnt recommend doing it because you could and probably will make your device useless and therefore will have to replace it. anyway, i strongly recommend you to not do this unless you are really good with computers
Posted on Sep 15, 2005
SOURCE:
It wont power on how do i get the palmone lifedrive to come on it dont even come on even when begin charged
Usually those symptoms mean a motherboard problem or a battery problem. Both are replaceable and worth doing if you use your LD.
You can try a power reset. Plug the LD in and hold the 5 way button down then reset the Ld using the reset button. You may need 3 hands to do this. Sometimes this will reset the power section and get you running.
Jul 17, 2009 | Palm LifeDrive Handheld
When you do a hard reset and go to secure erase it does not do anything
You need to have the 2.0 update installed before the secure erase will work properlly. You can download this from the Palmone website. It updates the hidden directory and changes some of the palm os so that it will now do a reset and restore properlly.
Thats the only thing that I can think of that fits your description.
Jun 19, 2009 | Palm LifeDrive Handheld
Lifedrive wifi
Does the wifi work at all after it resets? Have you applied the level 2 palm srvice pack to the LD? I believe the update changes how the wifi operates. If you go to www.palmone.com and go to the lifedrive page you should see a list of downloads for it. If you click on the 2.0 update there is a description of how to tell if you need this or if it is already installed. You just need to check the version of one file. Download and install the patch and see if that fixes everythng.
If that doesn't fix it you may have a more serious problem that could require replaceing or fixing the LD
Oct 27, 2008 | Palm LifeDrive Mobile Manager Handheld
Error 1316 - installation failure
Have you uninstalled the previous version of Palm Desktop?
Do you have more than 1 profile on your computer? Sometimes multiple profiles can make things difficult is software is installed logged in as one and then you try to install/uninstall as another profile.
Are you installing Palm desktop from a disk?
Try this file from palms site -
http://www.palm.com/us/support/downloads/windesk414e.html
Also, take a look at this-
http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=17525
Dec 06, 2007 | Palm Tungsten E2 Handheld
My Lifedrive won't boot up
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Versamail Errors
hi first of all here are Support Knowledge Library links: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(39328) there are two main reasons your mail will not get sent from VersaMail: 1) The outbound email server is not allowing your mail through. The server thinks your email is SPAM. Go to the section on Outgoing Mail server issues: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=95,E=0000000000299122694,K=3846,Sxi=5,useTemplate=Case.tem,CASE=39211#outgoing 2) You have entered some of the information incorrectly in your setup and need to check for typos and verify the settings with your ISP or carrier. follow all the instructions home page: http://www.palm.com/us/support/lifedrive/ good luck
Mar 21, 2006 | Palm LifeDrive Mobile Manager Handheld
TomTom Nav5 problem: Arm Read memory allocation error
I don't know what it is with those brits but I think they hate us here in the America's. I have TomTom Nav 4 on my wife's T3 and had problems with instillation but could not get support (real person) from tomtom. Did you buy the Nav 5 from Palm's website? I called them and they said that they were making one "JUST" for the LD but didn't know how long that was going to take. If anything if you did buy it from Palm you should try calling them and see if they can help you with it.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
palm os is a flash rom built into the device, the only way your going to be able to do this (which will risk the device itself and i highly recommend NOT doing) is if you can get your hands on a flash tool to flash the ROM with your version of pocket pc os. i have never seen it done, but there are rumors that a palm treo 670 has windows mobile 2003SE on it. i just wouldnt recommend doing it because you could and probably will make your device useless and therefore will have to replace it. anyway, i strongly recommend that you not to do this unless you are really good with computers.
Why does my PALM LIFE DRIVE RESTART
What was the error reported? Things to think about: 1. Have you installed the updater for LifeDrive? It's worth making sure you have the latest ROM. www.palmone.com/us/support for more details. 2. What extra software are you running? Some of the usual suspects include Docs To Go. Make sure you have the latest version of Docs To Go. 3. Consider removing all third-party applications and adding them back one by one to find the culprit.
Sep 12, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Handheld Logo
116 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
