Question about Penn Gt Series Levelwind Reels 330GTi
Motor not pushing boat after two thousand rpm's
I have a 1983 inboard- outboard 3.8 litre o.m.c. 6 cylender boat engine. the boat startsoff and runs well. After you push throttle above 2000 rpm's the motor revs, but the motor ceases to push or move the boat forward.
  • Anonymous Mar 18, 2009
    when i push the throttlein full my hull barely gets out of the water and i have 140 evinrude
The prop is cavitating. The outdrive is not trimed under enough or the prop is damaged (providing it is the correct prop.)
Posted on Jun 10, 2009
    Problem Solver:
  • 34 Answers
The Gear Changer is probably worn out
Posted on Sep 04, 2008
Have evinrude outboard serial number 1591802140. What is model number and year?
Hey Jan,
The model number/serial number should be on plate attached to the engine mount...You need the model number to determine year.
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 25, 2017 | Boating
Hi, have a mariner 75hp outboard serial number 9502368. Can you please identify year and model so I can order spares
Hey Arthur,
These guys will take care of you,,, that serial number doesn't satisfy the rewquirements for a search...? They will need more info.. more numbers on any plate..freeze plug..look around the outside of the engine carefully..
Jun 19, 2017 | Boating
How to winterize an inboard/outboard boat motor
Flush the motor with fresh water, drain and refill drive gear with fresh oil , the same with the motor, remove spark plugs inject 10 ml of engine oil into each cylinder, turn engine over by hand so cylinder walls are coated, refit plugs. I then like to spray every thing WD 40. Remove the battery if you have a trickle charger connect it.
Oct 20, 2014 | Boating
I just got a new boat this summer and I live in Seattle, where I will use my boat year round. I have been told that I should winterize the motor so it doesn't freeze in the lower temperatures. What should...
I used to live in the Chicago area. We definitely had winter (below zero).I went thru extensive winterization for the inboards and stern drives. I fogged outboards and put Sta-bil in the gas. I also ran the gas out of the carbs or drained them but the boats would sit unused for 6 months. Does the boat stay in the water? If on a trailer, lower the motor so it is in the run (trim down) and the water will run out. If you tilt it up after this for storage, cover the gear case as it can fill with rain water and freeze.
Jul 24, 2014 | Light Outboard Motor Boat Bass Fishing...
What are the types of engines for boats?
The main types of engines when it comes to boats are: steam engine, gas turbine, diesel engine, steam turbine, and gasoline engine.
Jan 10, 2013 | Boating
Hello i have a 200 Mercury OPTIMAX that i just changed the plugs wires and fuel pump thinking it would correct my problem and it didnt the problem is that when im running wide open for about 5 minutes it...
Jaysen,
Weren't the plug wires made into the ignition coils and spark plug caps?
..This sounds more like a fuel delivery issue than electrical... have you changed the fuel filter?.. does the fuel line bulb stay pumped TIGHT!!?
you do have new spark plugs!!
Jun 24, 2017 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Penn Gt Series Levelwind Reels 330GTi Logo
292 people viewed this question
Top Penn Sport & Outdoor - Others Experts
Mike Marcotte
Mike Marcotte
raysaw
Tom Chichester
Are you a Penn Sport and Outdoor - Other Expert? Answer questions, earn points and help others
