Question about Konica Minolta DiMAGE 7i Digital Camera
What are the flash metering modes? - Konica Minolta DiMAGE 7i Digital Camera
    Master:
  • 425 Answers
The ADI flash metering mode combines distance information from the auto focusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, and 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash
Posted on Sep 15, 2005
SOURCE:
My speedlite HVL-F42AM bought for Old Sony A100 fires before the Mirror has time to expose the CCD sensor as I can see the light through the viewfinder during shooting time. Only in Manual mode I fires...
No I wouldn't say there is anything wrong with your DSLR I would think that the flash sync speed is set incorrectly. Each camera model will have a specific shutter to flash synchronized speed.
I've had and used SLR cameras with sync speeds as low as 1/30 and DSLR's at 1/250.
With my studio camera under studio strobes with a shutter speed at 1/60th I do get a slight blink of light BUT, it's the flash duration that makes the exposure.
There is also a difference between a flash made for a film camera and one that is made for a digital camera check make sure teat the flash is compatible with the camera you are using, also check see what the camera syn speed is and set your shutter speed to that. If your camera is equipped with an "M" mode then it also has a "P" mode for program this is a common mode to use flash because the camera sets everything for you all you need to do is compose, focus and trip the shutter. If the exposures are not coming out right then another thing may be a factor and that's the light metering mode (if you camera is equipped) look in your manual there could be as many as four different metering modes, check to see what the manual recommends for flash photography for your camera.
Another thing I use digital flash on my film cameras BUT not a film flash on a digital camera they just don't sync right.
Cheers
Mar 27, 2011 | Sony HVL-F56AM TTL Flash
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
D80 SLR lens /flash prob lem
What are your other lenses? If they're not AF lenses, you're not going to get autofocus or metering.
Is your flash not working when popped up? Remember that the flash won't pop up automatically in Manual mode.
Oct 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
L-358 light meter doesn't change modes
Most probably the switch under the Mode button went faulty. Try to operate the button many times, sometimes it helps, if the culprit is corrosion or small debris inside the switch. If not, have the meter repaired at Seconic.
Oct 12, 2009 | Sekonic L-358 Flash Master Light Meter
Getting out of the Custom Functions menu
Had the same problem, in the custom function menu choose C.Fn-05 and 0. This should rreturn your flash metering mode to E-TTL. Worked for me give it a try.
leebutt101
Oct 30, 2008 | Canon SPEEDLITE 580EX TTL Flash
I think my flash is too bright?
Make sure that the exposure compensation is at zero. If that does not work, make sure that the flash is on automatic brightness. Check the manual if you do not know how to do either one of these.
Apr 11, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
580 ex speedlite
Turn on flash while pressing some of those buttons with good batteries
Try switching from Meter to Standard Mode and move head around.
Try move the flash head(flash tube) in Manual mode.
It's in electronic locked up because you're moving that flash tube zoom too much. 98% of photographers use that mode:-(
Alexander
atdlee@netzero.com
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
With Macro flash unit attached, and using the closest subject distance, images are extremely over-exposed.
The camera fails to control the flash output automatically due to the high intensity of Macro ring flash, causing the image to be over-exposed. Please set the camera as below to prevent a undesired result. Camera and Flash Settings - Set the sensitivity to ISO 100 using the function dial of the camera. - Set the flash metering of the camera to Pre-Flash TTL from the recording-mode menu. MACRO RING FLASH 1200 - Set the camera exposure mode to A or M mode. - Set the aperture to f/6.7. - Attach a ND filter x4 (0.6D) to the camera lens. MACRO TWIN FLASH 2400 - Attach a diffuser to the flash tube units. In case the flash tube and the subject is too close, eg. Not using the arms, set the camera exposure mode to A or M mode and the aperture to f/6.7. A subject at minimum distance may still be overexposed. Use exposure compensation to obtain the best result.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
My exposures come out inconsistent
You cannot use the E-10/20N in Program Mode with studio strobes. Studio strobes are not compatible with TTL (Through The Lens) metering. You will need to set the Mode Dial to Manual Mode. Exposure is determined by flash output , ISO and the distance from flash to subject. Proper exposure can be determined with a flash meter.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Open Questions:
Konica Minolta Dimage 7 delay in start up and shot down procedure Hi, I have a Minolta Dimage 7 Digital Camera SN91202050. I'm very keen in electronics and I have its service manual (45 pages). Few months ago, I upgraded the firmware to ver 2.01e. (I read the full compatebility notice before installing). The camera worked so fine. I've got about 2000 jpgs And the last day I took about 200 jpgs in a very short period of time. So I was enforced to exchange the batteries during the snapshots. I'm using 2500mAh MiMH Kodak batteries. I noticed that the grey front right hand part of the camera is a little bit overheated. The next day, and after the camera returned to its normal temperature, I tried turning the Main Switch/ Mode Dial from OFF to Recording Mode, after putting a completely charged batteries. Unfortunately, I heard a small sound "Tick" then nothing happened else, the Data panel stayed dim(unlit) and with no data, and no red indicator had seen, also the monitor LCD didn't start. I didn't hear the noises which the camera should give in normal conditions. I left the switch as is, few minutes later, the camera continued the startup procedure, as I heard the noises and the Data panel lit in green and it displayed the normal status. I made several snapshots and everything were going well. I turned the **** to playback mode, I have seen the entire snapshots I did. Which mean tha the CF card is working well. Also all the other knobs were working properly. Then I decided to turn the camera OFF. Again, the LCD monitor turned OFF directly, but the upper Data Panel was left ON!!! And I heard "tick" Few minutes later, it turned OFF automatically. And I heard the same noises in the normal manner. 1-Does that mean the main board had a cold welding point? Or, the board was affected in the earlier overheating. I tried to use the transformer instead of the internal batteries, and I found this same situation. Delay in the turn on and turn off. And also the delay period is the same. 2-Does that mean that some chemical capacitors were damaged? ( wich capacitor should I replace?). 3- Does that mean there is a cold welding in some points beyond the processor in the MAIN PCB ASSY(0402) due to the frequent humidity and overheating? N.B I tested the internal backup battery, and it gave 3.24V (it's ok) Kind Regards, Soubhi Sabbagh Email: s.sabagh@aloola.sy
Mar 13, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Konica Minolta DiMAGE 7i Digital Camera Logo
113 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
