Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Hard Drive not powering on
While running a movie off my hard drive today, i got an error message letting me know "device removal" had occured incorrectly. This often happens as the power serges but after re-pluging it is it is ok. This time I plugged it in and my computer wouldn't recognize it. I hear a high pitch sound when plugging it into a power source (tried three different) and the red light on the back flashes like it wants to turn on. But it will not fully boot. No blue light on top. No icon on my desktop. Nothing. I have a mac. I've restarted my computer. Nothing. HELP! My whole life is on this thing. I know, stupid but true.
Kschamu here is the only fix for you you need to go out to best buy and get a external hard drive shell and go into your external and remove the disc and put in in the new shell
Posted on Sep 07, 2008
IO error
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output
(I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Nov 25, 2012 | Western Digital WD5000AAVS 500 GB SATA II...
I/O error on Buffalo HD-PET500U2 Ext Hard Drive
If this error message appears when attempting to access the files on an input/output (I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
Hope this helps
Nov 16, 2012 | Buffalo Technology Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Windows Boot Manager message: Windows encountered a problem communicating w/a device connected to your computer. Error may be caused by unplugging a removable storage device such as an external USB Drive...
    Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
    Thanks for using FixYa
    Jul 23, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
    Got a Sumvision External 2.5 Hard drive for over a year now and today i pluged it in as normal and got the following error messages - using windows 7 also tried it in XP and it doesnt recongise the hard...
    Hook up that external hard drive to another computer that you know for sure the USB ports work properly. If you still get the same error message or the drive is not recognized then that means the hard drive is bad.
    If the hard drive is recognized properly and you can access the files then that means its an issue with the operating system.
    May 14, 2011 | Computers & Internet
    Dropped laptop off of couch onto floor apprx 18in. Computer locked up. unplugged and removed battery for five to ten minutes. started to boot and gives me "Windows has encountered a problem...
    If your hard drive was running at the time you dropped it, your hard drive might have crashed. Sorry to tell you this buy you most probably need to replace the hard drive.
    Apr 11, 2011 | Computers & Internet
    ON my Toshiba Satellite M-45 S355 I got a blue screen with a message; STOP: c000021a (Fatal System Error) The session manager initialization system process terminated unexpectedely with a status of...
    do not believe you need replace the hard drive
    i think you may have a registry error
    you may have a application conflict or surface error
    try booting in either step mode or safe mode
    step mode will let you know where in the boot process the error occures
    in safe mode you can run a registry utility like iolo system / registry mechanic
    & run error checking
    if you need neer to remove & backup your drive you can get a hard drive usb adapter cable set $10-$20 - less work
    Nov 04, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
    I/O Device Error on External Hard Drive
    try doing a disk check on it
    1 hold down the windows key and press r
    2 type in cmd
    3 in the shell window type in chkdsk /F /X e:
    Replace the E: with your harddrive letter
    May 04, 2008 | Computers & Internet
    Repeated Sudden Device removal
    Me too, i bought a LaCie BigDiskExtreme+ (1tb) and it keeps giving me Device removal error.  I'm running Mac OSX Leopard.  Worked for 5 minutes, now everytime it turn it on it goes away and comes back up, always giving me the error message.  Any advice ?
    Mar 26, 2008 | LaCie (301015) 120 GB Hard Drive
    SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
    127 people viewed this question
    Top SimpleTech Computers & Internet Experts
    Gareth Cockram
    Gareth Cockram
    Lyle Siemens
    Lyle Siemens
    Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
