Question about Sharp Heating & Cooling
I have a sharp dehumidifier dw51 and the water collection tub inside has broken. I need a replacement
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Take it off and run down toLOWES or HOME DEPOT!
Posted on Sep 04, 2008
UNIT IS LEAKING WATER BUT WATER BUCKET IS EMPTY
If the hose is attached the previous answer seems valid and correct. However, I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I noticed the port where the water collects to drain into the "tub" sometimes gets a slimy fungal growth on it. This is something that should be routinely cleaned . Just pull out the tub and look at top of Tub compartment. then wipe the portal with a cleaning cloth (use Lysol or similar if desired). This method helped mine significantly from "leaking". In the long run I placed a rectangular storage tub lid under it to protect carpet.
Jul 07, 2011 | Whirlpool 75-Pint Dehumidifier
Delonghi dem10 not producing water
I had this problem, so have a few people. Solved by replacing big yellow capacitor on circuit board inside. Instructions here: http://www.howtomendit.com/answers.php?id=358398
May 17, 2011 | LG DH30 GoldStar Dehumidifier
Whirlpool gold dehumidifier, fan is running, but not collecting water. It's in a bathroom, and the temp doesn't get below 60. filter was very dirty and the inside as well, from not cleaning the filter....
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 10, 2011 | Whirlpool AD35USS Dehumidifier
My Dehumidifier has stopped dehumidifying! The fan works and everything else but it no longer collects water. Its is a DESICCANT variant. The air coming out of the vent also used to be warm and this is no...
heatman101
Dec 12, 2010 | Heating & Cooling
The dehumidifier will run, but will not collect any moisture from the air. The screen has been cleaned, the tub is cleaned, but no water will collect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 07, 2010 | Haier HD456 Dehumidifier
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Aug 15, 2010 | LG Dehumidifiers
Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
May 14, 2007 | Crosley 40-pint Dehumidifier
Heating & Cooling Logo
54 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
