RCA RS2025 Bookshelf Stereo CD Player Hangs Up
Hi, I have an RCA RS2025 Bookshelf Stereo, about 5 years old. The CD changer stopped opening. I dismantled the unit to get to the CD changer, removed the 3 individual CD trays and operated the unit by manually moving the drive wheels through the mechanical cycle. I could not see any obstruction. Reassembled it and turned it on, leaving out the trays because I could not figure out how they were supposed to go in. Result: Same as before. It gets hung up in the cycle and stalls. After a few seconds, the word "rESEt" comes on the LCD screen. The stereo receiver works. The single tape deck has a broken drive belt. Any help here will be very much appreciated. Malcolm
    Genius:
  • 3,422 Answers
Ok,
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
Posted on Sep 04, 2008
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
A CD is stuck, it won't play, and it won't eject.
i would go to the website of the make of the 5 disk changer and click on the support page. there you should find answers to your problem
Mar 24, 2009 | RCA Audio Players & Recorders
Need help opening my CD changer?
When you turn on the unit, pushing eject or the open/close button should work. If it doesn't work then the unit is not working. See if you can send it back.
Nov 17, 2008 | RCA RS2025 CD Shelf System
My rca 5 disk vertically stacked cd changer is stuck. Won't open. How to fix it?
Try this... unplug the unit and turn it upside down.  Have a small screwdriver ready.  No plug the unit in and try to turn the wheel in the large slot clockwize.  When you see the spring clip try to grab the white plastic stop and move it clockwize.  This should eventually open the door.  It did for me.
Aug 03, 2008 | Thomson RCA Bookshelf System with 128 MB...
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
Will not open....
select another option such as "tuner", then go bak to CD
Dec 13, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
Blaupunkt IDC-A09 5-Disc CD
THE IDC-A09 CAN BE REMOVED BY INSERTING THE STANDARD PHILIPS REMOVAL KEYS INTO THE TWO HOLES EACH SIDE OF THE UNIT AND FORCING THEM OUTWARDS SLIGHTLY AND THEN THE UNIT SHOULD SLIDE FORWARD
Dec 03, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
RS2652C
I tilted the player to the right side (viewed from the front) to better see the speaker terminals and heard a clunk. When I sat the player back up I was able to open the drawer. I found two of the CD’s had fallen out of the proper holder on top of another CD (three CD’s in one space. After I put the CD’s back where they belonged the unit worked fine.
I assume one of the CD’s didn’t seat properly after playing and caused the mechanism to jam.
Hope this helps your problem.
Bob Michener
Sep 22, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
667 people viewed this question
 Grubhead
Grubhead
