Sony kp-48s70. how can the cabinet be opened to facilitate cleaning the inside?
  • 10,594 Answers
Give a close look on following pictures to open tv back and front cover. Hope this will help you.
sony kp-48s70. how can the - 5bda931.jpg ab202b4.jpg Regards,
Posted on Sep 03, 2008
I hit the power button, the light blinks a few times, no sound and picture, and the light stops blinking, then starts blinking again. It is a sony kp-48s70
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Dec 16, 2010 | Sony KP-48S70 48" Rear Projection...
I have a 48" sony projection with a rainbow comming down from the top
You have convergence circuit failure. Convergence IC's have to be replaced and probably some PICO fuses that soldered on the same board. This repair require good soldering skills.
Mar 09, 2010 | Sony KP-48S70 48" Rear Projection...
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
I hope someone out there can help me. I just got a Sony TV and it had a ruff trip over our gravel roads getting here. When we hooked it up it had a supper red screen and I tried to adjust it out. I get a...
poss red drive ic on crt module also crt on sonys have been known to have intermittant shorts in them you can go in to service mode@make adjustments for the red drive/or level
Nov 03, 2009 | Sony KP-53V75 53" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
My sony KP-48S70 is stuck in standby. How do I get this turned off?
Usually the tv is in standby because of a failure. Does the red light blink when you try to power it on and if it does, how many times?
Jul 07, 2009 | Sony Televison & Video
Tv not turn on
bulb is burnt out remove and replace.
Jul 05, 2009 | Sony KP-48S70 48" Rear Projection...
How do I perform a convergence adjustment on a Sony kp48s70 rear projection tv?
Hi, you picked a real difficult set to do, you`ll need the service manual,the original SONY remote, you may need to change out the ic`s and a few support parts, ie; resistors & chemical fuses which you can get at acme enterprises in orlando, be sure to read the entire convergence section of the service manual before you change any settings, my advice is to pass but gl if you go for it, video-tek
Jun 06, 2009 | Sony KP-48S70 48" Rear Projection...
Tv will not turn on
its a clicking of switching relay. cannot power on due to power supply failure.
May 30, 2009 | Sony KP-48S70 48" Rear Projection...
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
