Question about Belkin (F5D72304F5D7000) Router
Belkin router problems
Router modem and internet light shut off and re start when i am trying to download anything ie file ,program,my e mail.ect. dont know how to fix it Help?
    President:
  • 2,961 Answers
Check the belkin web site for any firmware updates, but if not and it continues, like mine did, the router is faulty and i would replace with a netgear other than another belkin.
Posted on Sep 03, 2008
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Downloading Problem
See if belkin has a firmware upgrade for your router - They may have already found and fixed a bug in the router and you just need to install it.
http://www.belkin.com
Dec 23, 2007 | Belkin (F5D5231-4) Router
Problems setting up Belkin wireless G+ mimo modem router/usb network adapter
It sounds like the router address is wrong or you are not connected to the network.. Guessing you are using Windows XP or Vista. Go to the DOS prompt (http://www.computerhope.com/issues/chdos.htm) then type ipconfig. This will bring up details on your network (see example below).
IPv4 Address. . . . . . . . . . . : 192.168.0.4
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
You should see default gateway address which is the address of your router ie 192.168.2.1 in your example. If this is not shown you have not connected to your router properly. If it shows a different address use the address shown to try and access your router. HTH
Nov 14, 2007 | Computers & Internet
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin (F5D72304F5D7000) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
