While using a Webcam on Yahoo instant messenger, whenever I try to connect to "see" someone who has a webcam, I get a message "A Network error occurred while connecting to the server" Is this a Yahoo problem or my DSL problem
This problem occurs especially because you opened another program that uses your webcam. You should close
any other program that might be using your webcam because a simple
webcam can only interact with one program. If it doesn't work, try
reinstalling it / then messenger with another version. If you are satisfied, please rate or/and leave a testimonial. Thanks!
first make sure your web cam is perfectly ok.
open yahoo messenger login your account
click messenger menu then click view webcam
then a window will open a warning message check donot show again then ok
then choose you internet connection choose broadband
then it will open a window with your webcam.
if you want your friends to view your webcam
just chat with them, and in action menu click invite to view my webcam.
you can see in your webcam window how many viewers you have and if you are broadcasting.
First check you installed your webcam driver or not? This problem also occur if you have slow internet connection. Use latest version of yahoo messenger. now its not work than give detail about your webcam i will try my best to solve your problem.
Webcam not Connected ( to your Messenger ) can usually be overcome by setting your Messenger Internet Connection
MESSENGER INTERNET CONNECTION
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'No proxies' or 'Connect direct to the internet' depending on the version of messenger you have make sure your internet connection and country are correct in the lower two boxes, If not change them > Apply > OK
if you have webcam program installed different to the default one. then you will encounter that kind of problem... solution, try to choose one of the webcam program and make it youre default one... or stick to the webcam default of youre messenger..
