Question about Konica Minolta DiMAGE 7i Digital Camera
What is the focusing screen display? - Konica Minolta DiMAGE 7i Digital Camera
    Master:
  • 425 Answers
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Posted on Sep 15, 2005
Ford focus radio clock not working
It would not be possible that a detail cleaning would cause that to happen. When you have no display on the screen it is usually the LCD display that has failed. Unfortunately that means a new radio.
Oct 23, 2017 | Cars & Trucks
Is there a focus for my F19251GY TV
Hello
Yes, of course there it is in every TVs. The focus adjustment in TVs determine the clarity of the display. It is a service adjustement and if you want to adjust it you should open your TV. It can be located at the Line Output Transformer [LOT], and integrated to it.
There will be two adjustable controls can be seen on the LOT. Out of which one is Focus control, and other is Screen control. Both are marked. Normally Focus control is placed on the top side and Screen control to bottom. Both controls are interactive, that is adjusting one will effect the other a little.
If your TV is out of focus, you just open its back cover and locate the said control. It will be usually marked as focus. Adjust a little while looking at picture to get a well defined focus. For this adjustment, take its menu display as reference rather than a moving object. Adjust it to get a well defined display. Place a mirror in front of your TV, so that you can see the image on it from back side.
A defective CRT [picture tube base] "socket" may also be the cause out of focus picture. It can be located on the base card of your TV, and can be detached from it desodered. If the above said adjustments did not give any results, the CRT Base may be defective. If base socket is defective, you can hear a very slght "shhhh" noice from it as you advance the focus control. Try to find out and rectify the problem. Ok
Oct 26, 2010 | RCA F19251GY 19" TV
Focusing screen information bar slanting
A scratch on the screen will not effect your photos in anyway, it will just be annoying to you at most. Its possible to hit the prism out of alignment but also very unlikely. If you had to **** it a little bit, its possible you may have moved the actual lcd.
Apr 12, 2010 | Canon EOS Rebel XSi Digital Camera
My camcorder can't focus, and I got a message
the display screen is distorted. I can't see anything,
Jan 02, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Focus
Use the Setup menu to select English or Spanish as
the language for the menus and on-screen displays.
Adjust Color Balance Automatically or manually
(PerfectColor TM) using six colors, Magenta, Red, Yellow,
Green, Cyan and Blue. Reset the Color Balance to the
factory default settings. Align the focus (convergence)
of the TV's projected light beams or reset the focus to
the factory default settings.
Jul 01, 2008 | Mitsubishi WS-65515 65" TV
The focus on the NIKON COOLPIX P80
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
May 12, 2008 | Cameras
Camera error
The problem is the internal focus lens is either stuck, or knocked out of alignment. The lens will need to be serviced, or replaced with a new (not cost effective), or good used lens assembly.
Aug 07, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Open Questions:
Konica Minolta Dimage 7 delay in start up and shot down procedure Hi, I have a Minolta Dimage 7 Digital Camera SN91202050. I'm very keen in electronics and I have its service manual (45 pages). Few months ago, I upgraded the firmware to ver 2.01e. (I read the full compatebility notice before installing). The camera worked so fine. I've got about 2000 jpgs And the last day I took about 200 jpgs in a very short period of time. So I was enforced to exchange the batteries during the snapshots. I'm using 2500mAh MiMH Kodak batteries. I noticed that the grey front right hand part of the camera is a little bit overheated. The next day, and after the camera returned to its normal temperature, I tried turning the Main Switch/ Mode Dial from OFF to Recording Mode, after putting a completely charged batteries. Unfortunately, I heard a small sound "Tick" then nothing happened else, the Data panel stayed dim(unlit) and with no data, and no red indicator had seen, also the monitor LCD didn't start. I didn't hear the noises which the camera should give in normal conditions. I left the switch as is, few minutes later, the camera continued the startup procedure, as I heard the noises and the Data panel lit in green and it displayed the normal status. I made several snapshots and everything were going well. I turned the **** to playback mode, I have seen the entire snapshots I did. Which mean tha the CF card is working well. Also all the other knobs were working properly. Then I decided to turn the camera OFF. Again, the LCD monitor turned OFF directly, but the upper Data Panel was left ON!!! And I heard "tick" Few minutes later, it turned OFF automatically. And I heard the same noises in the normal manner. 1-Does that mean the main board had a cold welding point? Or, the board was affected in the earlier overheating. I tried to use the transformer instead of the internal batteries, and I found this same situation. Delay in the turn on and turn off. And also the delay period is the same. 2-Does that mean that some chemical capacitors were damaged? ( wich capacitor should I replace?). 3- Does that mean there is a cold welding in some points beyond the processor in the MAIN PCB ASSY(0402) due to the frequent humidity and overheating? N.B I tested the internal backup battery, and it gave 3.24V (it's ok) Kind Regards, Soubhi Sabbagh Email: s.sabagh@aloola.sy
Mar 13, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Konica Minolta DiMAGE 7i Digital Camera Logo
141 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
