Question about Acer Aspire L100 PC Desktop
ASPIRE L100 overheating issue
I have one of this and having same problem of system shutting down by it self. What I found out is that with the cabinet open and the hard drive/CD drive cage support moved out from its place, with a FAN blowing air from the mother board, the system works fine.
The overheat componnents I belive are related to onboard video processor. To save my money, I am thinking about of replacing the original hard driver with a laptop hard drive(2.5') and adapt a fan into the space left on the cage support.
I am just affraid of installing the laptop hard drive, which is 5V in place of its original drive that seems to be 12V. Am I right on my concern? If not, could that work?
  • Grooving67 Apr 08, 2009
    Hi Bigdog12c, can you tell me the solution to overheating on my AcerL100. As you say it is not hard or expensive but takes time.
    KR
    Charlie
  • Roberta Smith
    Roberta Smith May 11, 2010
    if the hard drive you use now is run on 12 volts and you replace it with a hard drive that runs on 5 volts... it will fry it (to use a techy term).... please enlighten me abit.... is that a laptop ?
This Acer L100 is overheating due to lack of cooling to the Motherboard Graphics chip and chipset chip. If you take the unit lid off and remove the hard disk drive you will see 2 heatsinks. One of them can be cooled with an additional heatsink, which I have fitted on mine and it no longer overheats and switches off.
I can olso help with Hard drive issue you have. 3.5" desktop hard drives and 2.5" laptop hard drives in the SATA format both have the same power and data cable fittings on the drive, this means they will both work the same and will not fry. If you read some articles on Desktop PC's, you will see many people fit 2.5" drives into their computers too.
I think the extra fan idea would be good too, as this small form factor pc has an AMD processor and gets mad hot any way. Hope this all helps.
Tech Guy Batey :))
Posted on Apr 14, 2009
    Problem Solver:
  • 9 Answers
Bought one of these for my daughter. The problem is definitely heat & some driver problems. I was having same problem. If your running vista make sure to upgrade to service pack 1 & install all updates. Next upgrade all hardware drivers to latest. When I first pulled cover off the ram was so hot I could not touch it. Had two 512mb sticks one was bad from heat I suspect. Bought two x 1gb. The fix for overheating is not hard nor expensive but does require some time. Let me know if interested. This thing runs like a champ now.
Posted on Sep 25, 2008
I bought two of these and had both working for a year. When I did a recovery or heavy video streaming the computers crashed. I removed the heat sink and the factory thermal grease. I purchased new thermal grease that was 88% SILVER. The computers' STOPPED crashing. Everytime before it would crash you can hear the fans kick into overdrive. FYI go to Start-MSCONFIG-BOOT-ADVANCED OPTIONS-Select Number of Processor- 2 in the drop down window and apply. For some reason Vista by default is set to single core processor. You will notice an increase in speed during bootup
Posted on Apr 29, 2009
I have the same problem as everyone else, I did what someone suggested invert the fan, I think the fan throws the air to the outside insted of the inside. Also in bios or mother board configuration under pc health I disable the smart fan feature and made the fans blow at a faster speed, by doing this I have not experince any overheating problems. Hope this helps
Posted on Apr 21, 2009
I purchased two Acer L100s from Circuit City when they first came out. I am not a fan of mini/micro form factor PCs because you are limited to upgrading. After 11 months of problems (over heating, sleep, HDD, and dvd writer), and before sending it to Acer for repair I found that both PCs purchased at different Circuit City stores had the exhaust fan blowing air in the case, not out. I reversed the fans and my PC know run on average between 65 - 70 degrees celcius. Check which direction the fan is blowing on the back of your PC by placing a tissue on it. It should be blowing the tissue out, not sucking it in. Ever since I reversed the fans and changed the OS to XP, I no lomnger have issues with the PC overheating, not being able to come off of sleep, the HDD is no longer continueously active from a bunch of unneeded background processes, services, strings, threads, etc. I believe that this PC is and it's proprietary MOBO just barely passed Microsoft WHQL and HCL.
Posted on Oct 10, 2008
  • 49 Answers
Fyi...............i do not believe the heat problems in these models has to do with hardware..........it has to do with advanced power maneagement not maintaining its properties in the software side. bios, cmos smart fan and power options all get messed up over time.
Posted on Sep 29, 2008
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
    this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
    May 14, 2010 | Acer Aspire L100 PC Desktop
    Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
    The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
    Nov 18, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    L100 overheating
    In most of the cases the cooling radiator inside the computer is full of dust, clean it as well as the fanblades and things will improve.
    Try to find a place nothing is blocking the inlet on the back and the outlets on top and in the front, open the part which covers the usb and other connections on the front.
    Sep 30, 2008 | Acer Aspire L100 PC Desktop
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    ACER L100 OVERHEAT
    Are you comfortable with a little case mod. Just did this myself & solved overheating issue. If interested let me know & I will provide step by step instructions.
    Aug 16, 2008 | Acer Aspire L100 PC Desktop
    Computer shuts down for no discernable reason
    Im not a expert but my opinion would be to just buy a new power supply. Installation is easy. Thats one thing that gets replaced most often out of all pc parts. I would wait for a expert opinon though, good luck
    Nov 27, 2007 | Acer Aspire L100 PC Desktop
    Unwanted System Shut Down
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} ok guys this is the problem i work for Acer and basically if you own an aspire L100 then you have to be prepared to modify your little bad boy because of acers poor design and a crappy little fan the anything inside the case feels like its on holiday in the tropics what you have to do is side mount 2 extra fans with separate 12v supplies and your system will never overheat or die on you if you have any questions on how to do this just email me :-) me
    Aug 10, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    946 people viewed this question
    Brian Sullivan
    Brian Sullivan
    Mohammed Ebrahim M
    Mohammed Ebrahim M
