Question about Nintendo Video Game Consoles & Games
I HAVE PLUGGED MY WII IN AND SET IT UP WHEN I PUT A DISC INTO WII CONSOLE IT COMES UP ON TV BUT WHEN I PRESS MY REMOTE TO CHOOSE THE GAME NOTHING HAPPENS I HAVE BROUGHT A NEW SENSOR BAR AND CHANGED BATTERIES IN REMOTE WHAT CAN I DO
    Scholar:
  • 125 Answers
Are you able to see the 'hand' (that chooses options on the wii menu) on screen at all?
Posted on Sep 03, 2008
Everything is plugged in, the disc is in and the wii is on, on the other television, it used to come on autmatically but on my hitachi television, it doesn't come on automatically, i have pressed many...
Mine too, we need to find the AV channel. All our friends who have a Wii have had no problems, just plug it in and switch your remote from TV to AV and it's there. My Hitachi remote does not have a TV/AV button, and the other options, S.Video, Composite Video, Component etc is taken up with other things eg Foxtel, DVD player and DTT tv channels .... HELP!!!!
Jan 02, 2011 | Video Game Consoles & Games
Tip
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
on Feb 15, 2010 | Video Game Consoles & Games
Help me to put up my nintendo wii
1- Plug the video cable to both wii and T.V.
2- Plug the wii sensor in wii and place it at top of T.V.
3- Plug the power cord in both wii and electrical supply.
4- Press the power button and sync your wii remote.
Mar 13, 2010 | Nintendo Wii Console
How to connect a tv to a wii
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
JUST BOUGHT wii SPORTS FOLLOWED THE STEPS TO
The best thing I can think of is to turn on the wii, go to the tv and press tv/video once and if nothing shows up then press it again (this will take your tv to video 2) and if that doesn't work then turn your tv to channel 3 or 4 and see if one of those channels work, also if your wii is plugged into a vcr or dvd player make sure that vcr/dvd player is on!
I'd recommend just directly plugging the wii into the tv though on the count that its easier to setup that way...
If this doesn't work then call nintendo because their customer service is superb in my opinion.
Jan 25, 2010 | Nintendo Wii Console
Wii problem - Can't get past Select Language screen
keep getting a error has occurred,press eject button and remove the disc,then turn wii console off and refer to manual cant get past this.
Dec 25, 2009 | Nintendo Wii Console
When i put a game in the wii it won't play
To Access the WiiConnect24 setting:
  1. Access the Wii System Settings
  2. Move the cursor over the blue arrow on the right and and select it once to reach System Settings 2.
  3. Choose "WiiConnect24.
Hope this helps!
Dec 23, 2009 | Nintendo Wii Console
Wii systme not working
Just press the input button on your remote controller until the screen comes up. Make sure you are plugging the RCA (Red/Yellow/White) cable into the standard input cables on your TV.
Dec 20, 2009 | Nintendo Wii Console
Second remote will not recognize the wii mario kart. Second remote will work with all other wii games, except for Mario Kart.
Had the same problem last night.... Turn off the wii system by unplugging , wait a couple of seconds and plug back in. Next, the front of the wii has a pocket that opens, there is a red button. Put the disc to mario kart in the wii once you see the federal regs push and hold the red button on the wii for 15 seconds then once this 15 seconds is up with the controllers battery case open push the red button to the original controller. All of lights will flash and then stop. Push the red button on the wii console again just once. Then push the red button on the second remote wait till all lights stop flashing push the red button on the console and now they should be married to the wii system. Hope this helps----do you know how to get the volume? We don't have any volume
Jan 24, 2009 | Nintendo Mario Kart (Wii) for Wii
Wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Aug 01, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
