Question about Toshiba 65HX81 65" Rear Projection Television
Ur ignition card/panel????? - Toshiba 65HX81 65" Rear Projection Television
  • 1,800 Answers
Hi.
its the responsible part of TV ta ht gives signal to start working.
if that one is burned the tv will not start i don't mean will not turn ON but will not start.
u need a new one or maybe a fuse or circuit breaker in it is blown!!
plz rate this post.
best regards
Posted on Sep 03, 2008
Ignition wont work
if ur dash lights come on it may not be in ur ignition but in ur starter or sylinoid, the best place to start would be check ur battery voltage and connections along with the starter connections,if ur un sure u can replace the ignition or have ur starter tested at advanced or autozone for free but starter must be off the vehicle, best of luck
Nov 05, 2012 | 2004 Chevrolet Impala
Can not shift into park key will come out of switch
When ur keycan be pulled out even when ur running the engine or in the"ON" position. U have to replace ur old key or try to use ur spare key and see if it will come out of the ignition switch!
If it can't be pull out, the problem would be the ignition switch have to be replace, 'cause of eroded copper/brass pins inside the switch!
The problem of ignition switch key pull out would be the weight of other things attached to ur key chain! The vibration when ur running and many times u inserted the key, have lost the LUBRiCANT inside.Minimise the WEIGHT of ur key chain so that in the future the ignition key will not have any problem!
Hope that helps u out!
Nov 20, 2010 | 2003 Jeep Wrangler
Have no sound, do I need to download something
first check if a pair of headphones works if notmake sure ur speakers have power going to them make sure speakers are plugged into the the right audio output (usually light green color in the back of ur computer) check (if ur using a PC) in control panel-sound settings, if your sound card is ENABLED. you can also go to control panel-device manager, and look for an yellow exclamation points(if you see one next to, lets say sound card, it will mean that you need to download drivers for your sound card) if ur computer is dell then go to www.dell.com and look for support option, drivers, etc. any other brand PC, just find it on google, go to manufacturer's website and follow the same format...support....drivers. hope this helps
Jul 13, 2010 | Dell A215 Computer Speakers
3D USB sound card won't work my laptop won't let me adjust volume controls i tried in control panel but no luck
u can do it....re-conenct the USB sound card....but only after u do the foll...
can u get into BIOS ?
if yes...
then dissable onboard sound in BIOS...then save config in BIOS using the save and exit option in BIOS menu....then connect ur USB sound card to the USB port and connect ur speaker to the sound output in that...and reboot...
now it should work...
ur system will auto detect
Dec 31, 2009 | Adapters.com USB 2.0 3D 5.1 Channel Audio...
No audio
never delete files from ur Control panel>
go to Control panel and try and check for the Sound properties> find them and chk if the Speakers are selected as the default or not>
Still if doesnt respond> search in google and download the latest Codecs on ur computer
Oct 08, 2009 | Intel Premier Resources 4-Channel 32-Bit...
No sound in vista through sound card
U should check the line in volume. go to control panel-sound and audio-recording devices-line in properties-and then unmute from here. If already unmuted then check out that ur microphone properties has enable listen audio on ur speakers.
Oct 06, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
How can I open my nokia n72 phone to insert a SIM card?
just turn backside ur mobile you will see the small oval shaped button below .just press it with ur nails and pull downwards.urs back side panel opens .just simple
Jul 28, 2009 | Nokia N72 Cellular Phone
How can i add songs ain motorazer v3i's itunes folder.
Hai Dud,
First off all make sure u installed into C:/drive(by default) where ur OS is installed,then only u can add songs.
1. If all are doen correct by u...then open iTunes & make sure ur mobile is connected to the system,the software will detect ur set and list on left side of Itunes panel.
2.In left panel of iTunes on top select MUSIQ or LIBRARY drag and drop ur favorite songs into it.
3. After all drag and drop operations done,select ur mobile from the panel.
4. Down on the screen select ur folder as i.e MUSIQ or LIBRARY,then click on add or automatically it will synchronous.
5. Don't unplug ur device untill synchronisation completely finishes...or else ur memory card will be damaged.
6. After all successful synchronisation,it will prompt that "process completed"!
7. Now Enjoy!
Hope it Helped You,If so give an "High Five!" [;)
Jul 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
Toshiba 65HX81 No Power Issue
ur ignition card/panel is burned change it!!
Aug 16, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
