Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi TV wd-62725 won't turn on
Hi-
We've been having this problem for a while now. TV won't turn on- push power button and it seems to try to "boot up" but then, before the picture even comes up, it shuts itself off. Sometimes if you let is sit (for weeks) it will work again randomly, and then, just as randomly stop working. It's not the lamp. We had a tech come out and realign the prongs in the lamp cartridge assembly, and that worked for a while, but now we are having the same problem... same symptoms, but the "fix" the tech did is still secure. red status light flashes 3 short and 1 long. the tv is only about 3 yrs old. Any assistance would be helpful! or any links to the service manual!
thanks,
Janell
  • 2 more comments
  • neoikon Sep 16, 2008
    For me, the green light blinks forever and never allows me to turn it on.  I've tried disconnecting for long periods of time and tried holding the reset for a long time.  No luck.
    I disassembled the TV and found some blown capacitors on the power board, but after replacing those, I get the exact same behavior.
    I've heard the symptoms I have having are due to problems with the DM board.  I look at the DM board and I don't see any blown capacitors on it (I was hoping to).
    Here is a link to the service manual:
    http://tv.manualsonline.com/ex/thread/vi...
    http://tv.manualsonline.com/regman/exit/...
  • wrd5 Dec 01, 2008
    Did you have any luck getting the TV fixed?
    I have the same problem.
  • tv o rama Dec 20, 2008
    just changed lamp,red light still on and no power
  • Anonymous Apr 28, 2009
    i have the same problem my lamp button comes on
  • 103 Answers
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Posted on Apr 26, 2008
SOURCE: Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Posted on Nov 02, 2008
  • 179 Answers
SOURCE: I have a Mitsubishi WD-62525.
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Posted on Nov 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a rappid flashing green power light and the
You Can get the V26 Chassis DM repair kit at www.tvrepairworld.com which usually repairs that issue. The kit contains the parts and a CD with instructions.
Posted on Oct 07, 2009
  • 52 Answers
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
Posted on Nov 14, 2009
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Tv modle wd-62725 after power outage timer light blinks constantly and will not power on even after trying system reset
what do i do when this problem occurs ive already tryed to do the reset button but that didnt help at all?
Jun 30, 2010 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd 62725 medallion
have you tried the reset button on the front panel ? you need something small like a paper clip, or pencil to push it in.
Jan 03, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much.  My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed.  I sure think Mitsubishi should be held more responsible than they seem to be.  Some one suggested a class action lawsuit.  I would sure join one.  Jack P
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
1,604 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
