Question about Motorola Cell Phones
A little wet - Motorola Cell Phones
How do i fix a razr cellphone that has gotten wet ,and now when powered on a previous alarm set comes on?
Posted on Dec 25, 2008
My phone ids a little wet
If your question phone is a little wet, then take the battery out, wipe off all visible moisture, then put the phone in a bowl of uncooked white rice, completely covering the phone and leave it for a couple of days. The rice will draw out the moisture and usuall this works pretty good.
Feb 10, 2013 | Sony ST21i Xperia Tipo Black
What lubricant to use on a mk wet saw
I know that graphite works pretty well in wet situations but may not stay on as long. Any type of silicone spray should work and should not wear off as fast. In the past I have used good ole bearing graease, like you would use in marine applications. It should stay on long but just a little messy if you don't have easy access to the bearing. I had an MK wet saw myself and used marine grade bearing grease. You just have to get a large tube for just a little grease is the only problem.
May 06, 2012 | Mk Diamond Saws
My phone got wet just a little bit and ive tried drying it with a blow dryer and taking the battery out and stting it alone.what do i do? i only touched it while my hand was a little wet
the blow drier was a bad idea, any time electornices get wet, you should power them off if not already done so, then take them apart (battery and any other parts that are not going to ruin warrenty) and then just sit them out and let them dry naturaly, the heat from a drier could damage components, do not attempt to re power the device until you 100% know that it is dry on the inside to prevent short circuting
Apr 20, 2011 | Cell Phones
My Tokina 12-24mm /f4.0 for Canon got a little wet. When attempting to take pictures I get a ERR 01 message in my canon. Got the same error when I attached the lens to a second canon.
One of the internal circuits on the lens got more than a little wet. How long did you let it dry before putting it on the camera (which applies voltage to the possibly still wet circuit and probably shorted it out) ?. It sounds like a trip to Tokina is in order, unless you want to start a career as a repairman yourself
May 27, 2010 | Tokina 12-24mm /f4.0 for Canon
My sony cybershot t90 got little wet
The actual working part of the camera is not affected as the picture is taken properly. But the display part of the camera is only affected.The wetness might have penetrated across the sides of display screen to the inner parts.The display part needs replacement..
May 23, 2010 | Sony For Cybershot Dscwx1 Tx1 T90 T700...
My phone got wet. Dried it up. Now it just keeps
try shutting it off and pull the battery and let it dry a little bit more sounds like your backdraft chip is still wet
Aug 14, 2009 | LG CF360 Cell Phone
Ipod got wet while riding in the rain, now it doesn't work
Well if you know it got wet the first thing would be to let it dry out completely before even trying to power it on. If you did attempt to power it on while it was wet you may have shorted it out.
It's a matter of preference as to what you want to do from here, if you don't have a warranty on it anymore you may have to buy a new one.
There is little even a repair shop could do, as they would have to replace the components and would cost around the same as a new one.
Mar 17, 2009 | Apple iPod nano
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 | Vacuums
Cell Phones Logo
41 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
