Question about RCA L32HD31 32 in. LCD HDTV
RCS HD Guide Plus TV
My TV worked fine lastnight . I shut it off and went to bed. This afternoon I went to turn the TV on and all it did was click like it usually did when it turned on, this time it didn't turn on all it did was click a couple of times. Now it doesn't respond at all to ttrying to turn it on?
Any suggestions?
Thanks
Mike
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown that's why you can hear a click sound. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Oct 10, 2008
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
TV will not turn on
You need to look inside next.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 09, 2010 | LG 42LG50 42 in. LCD HDTV
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
Dec 20, 2009 | Televison & Video
Lastnight my family and I went fro a drive all was
Sounds like your alternator is bad and drained your battery. Try recharging your battery and putting a new alternator on it.
Sep 23, 2009 | 1999 Ford Expedition
Worked fine lastnight but this morning when I tried to turn it on there was no picture, but there is sound
TRY UNPLUGGING IT FOR FIFTEEN MINUTES THEN REPLUG IT IN,KNOW IT SOUNDS STUPID BUT WORKS SOMETIMES
May 21, 2009 | RCA L42WD250 42 in. LCD HDTV
RCA F32649 32" guide plus TV
you need to check the fuse ,maybe it's busted.
Sep 04, 2008 | RCA F32649 32" TV
Tv is dead
Try unplugging it for a minute and then plugging it back in, it might just need a "reboot" in the internal components. Does it make any noises? Is it a tube, lcd, dlp, or plasma?
Jan 04, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
RCA L32HD31 32 in. LCD HDTV Logo
149 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
