Question about Konica Minolta DiMAGE 7i Digital Camera
Is the viewfinder of the DiMAGE 7i high eye-relief type?
    Master:
  • 425 Answers
Yes, the eye-relief is approximately 20mm from the eyepiece lens and 17.5mm form the eyepiece frame.
Posted on Sep 15, 2005
SOURCE:
I just purchased a 4GB SanDisk Extreme lll CompactFlash for my camers but when I try to use it I get the Unable to use card message. What can I do?
I suspect 2GB is the maximum the camera will take. A 2GB Sandisk card works in my 7i. When the DiMAGE 7i was launched, 256mB was about as big as CF cards got!
Sep 06, 2010 | Konica Minolta DiMAGE 7i Digital Camera
KONICA MINOLTA DiMAGE 7i COMPATIBLE COMPACT FLASH CARD
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
Sep 22, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Minolta dimage 7i powers up all functions but lcd and viewfinder are blank
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Oct 27, 2007 | Konica Minolta DiMAGE 7i Digital Camera
Viewfinder
Please check the rotary switch on the camera is in the correct position. The viewfinder and monitor settings are very close together! You can download the manual from the link below: http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z10/D_Z10_E.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
What is the operative temperature of DiMAGE 7i?
It is approximately 0 to 40 degrees centigrade in temperature, and 5 to 85% in humidity.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Does the DiMAGE 7i support remote control?
Yes, it does. Wired remote release is capable via Remote Cord RC-1000S (1 meter) or RC-1000L (5 meters).
What is the Digital Effects Control (DEC)?
With this function, you can adjust exposure, contrast, and saturation through the viewfinder itself, prior to image capture. You can check how your adjustments will look using either the viewfinder or the LCD monitor. This feature makes it easy to get the unique images you want in many different shooting situations. DiMAGE 7i is capable of setting contrast, color saturation and filter in the following increments. Contrast: In seven levels from -3 to +3 Color Saturation: In seven levels from -3 to +3 Filter: In seven levels ranging from warm (reddish) to cool (bluish) colors.
What is the number of recorded pixels on the DiMAGE 7i?
The DiMAGE 7i has four different image size settings; Full 2560x1920, UXGA 1600x1200, XGA 1280x960 and VGA 640-480. The recorded pixel size in each mode is almost equivalent to an image captured with a 5 mega pixel, a 2 mega-pixel, 1.3 mega-pixel, 0.35 mega-pixel DSC respectively.
What is the number of pixels of the EVF?
The ferroelectric 4.8mm (0.19 type) reflective micro LCD adopted for DiMAGE 7i's EVF has approximately 220,000 pixels.
Open Questions:
Konica Minolta Dimage 7 delay in start up and shot down procedure Hi, I have a Minolta Dimage 7 Digital Camera SN91202050. I'm very keen in electronics and I have its service manual (45 pages). Few months ago, I upgraded the firmware to ver 2.01e. (I read the full compatebility notice before installing). The camera worked so fine. I've got about 2000 jpgs And the last day I took about 200 jpgs in a very short period of time. So I was enforced to exchange the batteries during the snapshots. I'm using 2500mAh MiMH Kodak batteries. I noticed that the grey front right hand part of the camera is a little bit overheated. The next day, and after the camera returned to its normal temperature, I tried turning the Main Switch/ Mode Dial from OFF to Recording Mode, after putting a completely charged batteries. Unfortunately, I heard a small sound "Tick" then nothing happened else, the Data panel stayed dim(unlit) and with no data, and no red indicator had seen, also the monitor LCD didn't start. I didn't hear the noises which the camera should give in normal conditions. I left the switch as is, few minutes later, the camera continued the startup procedure, as I heard the noises and the Data panel lit in green and it displayed the normal status. I made several snapshots and everything were going well. I turned the **** to playback mode, I have seen the entire snapshots I did. Which mean tha the CF card is working well. Also all the other knobs were working properly. Then I decided to turn the camera OFF. Again, the LCD monitor turned OFF directly, but the upper Data Panel was left ON!!! And I heard "tick" Few minutes later, it turned OFF automatically. And I heard the same noises in the normal manner. 1-Does that mean the main board had a cold welding point? Or, the board was affected in the earlier overheating. I tried to use the transformer instead of the internal batteries, and I found this same situation. Delay in the turn on and turn off. And also the delay period is the same. 2-Does that mean that some chemical capacitors were damaged? ( wich capacitor should I replace?). 3- Does that mean there is a cold welding in some points beyond the processor in the MAIN PCB ASSY(0402) due to the frequent humidity and overheating? N.B I tested the internal backup battery, and it gave 3.24V (it's ok) Kind Regards, Soubhi Sabbagh Email: s.sabagh@aloola.sy
Mar 13, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Konica Minolta DiMAGE 7i Digital Camera Logo
65 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
