Question about Kenmore Elite HE4 Electric Dryer
Kenmore Dryer heat is on high on all three settings
Kenmore 110.96284100 (62841)
Heat is on "high" on all three settings--"delicate", ":perm. press" and "cotton".
How do I fix that?
M. Daily
  • 5,911 Answers
Before assuming you have a component problem with your dryer, ask yourself this question, "When was the last time I inspected and cleaned my dryer ventilation?" If you can't remember, or if it has never been done, you may have a simple case of a dryer exhaust system that is clogged. A dryer requires proper air flow in order to work properly and efficiently. If the dryer is clogged, the heating circuits actually will overheat. The result will be longer dry times, a dryer that is too hot, or eventually a dryer that fails. A simple way to determine if it IS an exhaust problem is to perform the following:
1. Pull the dryer away from the wall and remove the exhaust hose.
2. Start the dryer with a load. The air at the exhaust should be forceful and warm (about 140 degrees F for most dryers).
3. If the air is warm, allow the clothes to dry to see if they dry efficiently like they should.
4. If they do not, or if the air flow is weak, inspect the dryer blower fan housing to make sure it is not clogged and that the fan is moving.
5. If the air flow is normal and the clothes dry just fine, reconnect the exhaust vent and check the air flow at the exhaust where it leaves your home. If the air flow is weak, I recommend cleaning the ventilation, and checking for any kinks that may be obstructing air flow.
6. If the air flow at this point is normal, and your dryer is still not operating correctly, then we may have a problem. A common problem is the wire coming off the auto dry sensor inside the dryer. The auto dry sensor bar is located inside the drum along the front. There is a connector wire that attaches to it behind the lower panel.
Inspect your dryer first and make a determination of what it is or isn't doing correctly. I would hate to recommend parts without you first doing some routine inspections. It could be that you may not need any replacemnt parts and may just be able to save yourself a service call. I hope you find this information helpful. If you need addtional assistance, please let me know.
PS It is recommended that you use the semi-rigid metal type dryer exhaust hose. It is crush resistant, heat resistant and hold up well against rodents.
Posted on Sep 03, 2008
  • Renee Hively
    Renee Hively Nov 29, 2013
    it is clean and away from the wall
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me melissamaemartin@yahoo.com I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
Kenmore 70 series dryer 110.96573220 only heats on time dry and delicate, not on normal
I would check the temp switch located in the console panel, sounds lile maybe the contact is burned since you have heat on delicate and timeddry.
Feb 02, 2013 | Kenmore 60172 Electric Commercial Dryer
Kenmore 700 series dryer little temperature difference between delicate and high
Using that thermometer I am guessing that the readings are close to what they should be. Typically there is not as big a temperature change between the two settings. What made her first think there was a big problem in the temperature settings?
Jan 22, 2013 | Kenmore Dryers
Problem with a Lady Kenmore Model 902202
You might as well go ahead and replace the machine, the cost to repair this problem is going to shock you.
Jun 25, 2017 | Kenmore Washing Machines
How long is the burner heat cycle supposed to be for a 2007 kenmore dryer
"How long is the burner heat cycle supposed to be for a 2007 Kenmore dryer?"
That would depend on which dryer setting (permanent press, cottons, delicate, etc) you had it set on and the amount of time you had it set to dry. The time setting is really what determines how long the cycle will be. The other setting determines the amount of heat that will be needed for that selection..
Hope this helps ....
Mar 25, 2011 | Heating & Cooling
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
I have a Kenmore 64812 (110-64812200) electric dryer that produces a high heat at every temperature level, even "delicate/cool" is hot. With two thermostats and a fuse, what could be broken first?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Thermostat is bad...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2010 | Kenmore 64812 Electric Dryer
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Kenmore Elite HE4 Electric Dryer Logo
210 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
