That's a sign of corrupted operating system( Win 7 ).
You have to reinstall the Window 7 again.
Hope that helps you out!
Possible that PC is hanging up as there is fault on the OS ( operating system) . So open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date. You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
bluescreen can be caused by a number of things
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you dont want to install more ram uninstall some unnecessary programs
a bad or faulty motherboard lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
a bad driver loose or faulty lead or not having enough ram
if you do get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps
1. >>>Turn on the Deskjet D2360 and the computer. Make sure the USB cord
is not plugged into the printer.
2. >>> Open the computer's web browser and go to www.hp.com. Click on
"Support and Drivers" at the top of the page and select
"Download Drivers and Software." In the blank box type "Deskjet
D2360" and press "Enter." Select the operating system your
computer is using, then click on the "Full Software and Drivers
Download" link. A download dialog window will come up. Choose a place on
the computer's hard drive to save the installation software.
3. >>>Double-click on the installation software to launch the installer.
Follow the on screen instructions, which will vary based on the operating
system you are using. When the installation process is completed, restart your
computer.
4.
>>>Plug the USB cable into the printer and computer, making sure it is securely in place on both ends. The printer is installed and ready to use.
