Question about Minolta Maxxum 7000 35mm SLR Camera
Blinking film on screen.
While I was taking pictures, near the end of my film, the camera stopped allowing me to snap any shots. The screen is blank regardless if it's on or off, except that the film is flashing. My first instinct was that the batteries were dead, but I just replaced them, and it's still not working. I've pressed the P button above the on/off switch, and it resets it for a second, while making a mechanical rewinding sound.
Help me please. How do I get my camera back up and running?
    Problem Solver:
  • 17 Answers
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
-John
Posted on Nov 08, 2008
The film comes out all blank when I take a picture on my Fujifilm instax 210. What do I do?
try take 10 shot without any films insert to the camera.
If there is flash mean camera is working in goods condition.
It will appear black because someone had open the film cover before, therefore , it detect it's a new film box, and eject the first film cover.
film will appear black.
Sep 23, 2013 | FUJIFILM Instax 210 Film Camera
The new roll of film winds into the right spool upon closing back cover // brand new batteries displays 1/2 and ERR appears on led panel
Is the ERR blinking, and is there an additional blinking E on the display? If so, the film is not loaded properly.
The film is supposed to advance all the way to the take-up spool upon loading. The camera then "rewinds" one frame at a time as you take pictures. This way the camera knows exactly how many shots are left on the roll. Also, if the back is accidentally opened, the shots already taken are already in the can and won't be ruined.
If you need a manual, you may download a copy here.
Try cleaning the battery contacts and see whether the battery reads full with no film in the camera.
If problems persists, feel free to reply to this post and give any additional details.
Mar 04, 2012 | Nikon N75 35mm SLR Camera
I cannot take any picture on any mode whether its regular snap shots or on portrait or landscape. The red recording light comes on no matter what I do! Please help
Your dial is in film mode. Put it back on the green button and fire one picture
take the battery out for a sec before testign this
cheers
rene
pls add kudo's
May 27, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
For several years my C-3020 zoom camera has worked fine. Suddenly, now when I take a picture, the picture leaves when I snap the shutter. Always before the picture remained on the screen so I could see if...
In the camera menu, there should be a setting for "review" to allow you to set the number of seconds the picture remains on the screen. Also, you can always review the pictures you've taken by pressing the review button on the camera...it's usually a button with an arrow that points to the right.
Jan 21, 2011 | Olympus Camedia C-3020 Zoom Digital Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
My Minolta Maxxum 700si is blinking HELP on the screen
That same problem popped up on mine about three months ago after I put new film in it. I was only able to get a few shots out of it before HELP appeared in the window. Then everything locked up. I was able to reset the HELP by taking out the battery momentarily, but the problem reappeared. Also, after that, my pictures were mostly blank.
I opened up the back and found that one of the four thin metal shutter "flaps" had popped out and was jammed out of place. I probably snagged it with my fingernail when I loaded the film. I was able to tuck it back in place and now the HELP problem is gone.
Haven't taken any pics yet, but I'm hopeful. BTW, it also fixed my built-in flash, which had stopped working, also.
Jun 10, 2010 | Minolta Maxxum 700si 35mm SLR Camera
I have a Canon Sure Shot 115u II Date 35mm Film Camera. No manual. How do I fix the blinking icons on the LED screen? There are a series of dashes along the top of the screen. They look like a place...
remove the battary and the film,the clean the contcts of the bat and bat comparment, and put the battary then operate camera without film.finding it normally operating for 10-20 clicks,put the film and try
Mar 04, 2010 | Canon Sure Shot 115u II Date 35mm Film...
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Dec 19, 2008 | Nikon F65 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Minolta Maxxum 7000 35mm SLR Camera Logo
213 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
