Question about Sony Ericsson Walkman W810i Cellular Phone
Flashing white screen
I need to get into phone to get my numbers out all stored in the phone memory.
    Brigadier General:
  • 7,752 Answers
The phone's firmware needs to be reflash on the phone to correct these issues....this can be done at your nearest repair center or online at topsony.com.
Posted on Sep 13, 2008
Nokia 6300 Memory Store Not Ready Then White Screen Appears
Bro. . Goto any mobile software shop and flash your mobile. This is software problem
Feb 25, 2012 | Nokia 6300 Cellular Phone
How do i store numbers in my prolectrix big button speaker phone please
  1. Lift the handset or press the Handsfree button.
  2. Press Store/memory.
  3. Press the 0 - 9 buttons you want to use as the memory location.
  4. Enter the phone number you want.
  5. Press the Store/memory button to confirm. You hear a confirmation beep. The number is stored.
Aug 01, 2010 | Big Button REIZEN Speaker Phone -...
I am getting white screen after starting my blackberry 8520 curve and iam getting application error 523 and resetso what i have to do
Hi, when a phone displays white screen and error messages, it means that an application you downloaded or an application downloaded from the internet has corrupted the phones memory and to be able to restore it, you will need to flash the phone memory.
You can use the link below to learn more and flash the memory of the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
take care.
May 25, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have the nokia 5800 xpressmusic which i have just got. in the top right hand corner there is a envelope flashing, when you click on it its says simcard memory full, i have all ready cleared the numbers...
If you've just put your SIM card in your Nokia 5800, you may have noticed a flashing envelope icon at the top of the screen.
This icon indicates that the SIM card's own text message storage is full. This doesn't actually cause problems on the 5800 because it stores its messages in the phone's own memory, but the envelope can look a bit annoying.
To get rid of the flashing envelope:
1. On the standby screen press the white menu button.
2. Select "Messaging"
3. Select "Options"
4. Select "SIM Messages"
5. Delete some or all of the messages from the SIM messages folder using the Options menu.
This should make the flashing envelope go away. You only have to do this once because when the SIM card is emptied it won't fill any more, as the 5800 does not store messages on SIM cards.
Nov 19, 2009 | Nokia Lands Phones
I have 5.8 vtech phone. A set of 3. I would like
Delete a Number/Name Stored in the Directory
1. Press . The screen displays DIRECTORY.
2. Press or to scroll alphabetically through entries stored in directory.
— OR —
Press the dial pad key for the first letter of the entry you want to delete.
3. When the screen displays the entry you want to delete, press select . Then press or until
ERASE flashes.
4. Press select . The screen displays ERASE NO YES and the number. The current choice
flashes.
5. Press until YES flashes.
Sep 07, 2009 | Lands Phones
My N-6233 displays white screen when i switch on
i think your phone memory is full just re-flash program or connection of ic display was broken - re hot by air hot gun if you dont have bring it to service store
Aug 14, 2009 | Nokia 6233 Cellular Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
White screen with red and blue lines
Try removing the battery for a few seconds and see if that clears up the issue.
If it does, be aware that it's most likely a temporary fix. You'll want to go through the phone and clear out some of the memory (saved text message, call log, and even pictures if there are a lot of them). You might want to consider stopping in at your carrier's local store and getting the software flashed as well.
May 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
K800i white screen at startup
try removing the memory card and then boot the piece.
Apr 21, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
