Nintendo Wii Console Logo
Posted on Aug 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Anonymous
Level 2:
Scholar:
  • Expert 55 Answers
  • Posted on Aug 09, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
55
Questions
0
Helped
33174
Points
178
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
My cisco asa 5505 lost it image file ... how can i get the image back
if it is really deleted from FLASH, you will need to connect to ASA with a console cable, start up TFTP server on your pc, and in TFTP copy your ASA image file (.bin - on your CD that you got with ASA) so that you can get it from pc to asa.
then use tftpdnld command to set all the parameters on asa and start the download of the file from your pc .... after it has been done - just reboot asa :)
Cannot see my network printers after installing ASA 5505
1. Please check your printer's IP address and port number is permited in your cisco firwall or not.
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
1helpful
Cisco ASA 5505 Firmware
Yes, it is possible and Yes you have to purchase it from Cisco.
Sorry, that is how they make the big bucks.
Consider a service contract on the unit, then you can download the firmware much cheaper.
3helpful
Cisco ASA 5505 firewall support URL filtering or not..????
Hi, the Cisco ASA 5505 is the base model, and URL filtering is not available on this model. The first model that allows URL filtering is the 5510, and every model above that. You can view the models and features here:
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Wireless router through Cisco ASA 5505 series
put the one cable to wan which come from internet and you have to connect the pc or any other connection then you connect in the lan
2answers
No power to cisco 5505 ASA
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
From the US, you can call: 1.800.553.2447
From there, Cisco will be able to tell you what your warranty status is by the device's serial number, and can also provide you with a quote if your warranty has expired.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
