Question about Star 39 JetStar Popcorn Maker
Stirring paddle The Stirring paddle slows down when kettle is full on my Star 39. I believe the gears are stripped, any replacments available? Thanks Jim
Canada dealer
I've bought a few of these for my mother on Amazon. Replacement lids, handles etc are available too. Search for 'Tefal Actifry spares'
Sep 17, 2013 | Tefal Actifry Replacement Stirring Stirrer...
I need replacement kettle for a popcorn maker 39-A
That kettle is available from Partstown.com. They are a restaurant parts distributor. But be prepared, that part is in the $600.00 range. It generally is nor feasible to replace a kettle on that model.
Dec 02, 2012 | Star 39 JetStar Popcorn Maker
Full clutch pedal but gear shift will not go into any gear
could be damaged "selector forks " in the gearbox or a faulty clutch master cylinder
gearbox needs to come out of vehicle and be stripped down to check for damaged fork's this will be expensive.
master cylinder service kit's are available get this checked first far cheaper than a new gearbox
Apr 22, 2012 | 2003 Kia Spectra
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
I have a Star model 89, manufactured in about 1986. Its a 14 oz kettle, and everything works, however the kettle will not pop the corn. The kettle is hot to the touch from the outside, but will not pop...
Make sure your agitator arms are properly functioning. If the corn is not being properly stirred, it will not pop. Also, make sure you are using the correct type of popcorn oil.
Nov 04, 2010 | Star 39 JetStar Popcorn Maker
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
2004 Dodge Stratus Transmission
Flushing your transmission will actually do more harm than good. Sure, it stirs up everything so that you can pull out the contaminants, but stirring up the debris will clog the valve body and can damage the filter. The best thing to do, if you are looking at changing the transmission fluid is to drop the pan and drain it, then you can replace the filter too and then put a new gasket on there and refill it.
Jan 19, 2009 | 2004 Dodge Stratus
Popcorn maker jams up - burns kernels
Please call Nostalgia electrics at 1-920-347-9122 so we can help you get the piece you need.
Nov 25, 2008 | Bond Helman Old-Fashioned Movie Time...
Need missing gear that drives strirring rod for popcorn machine
Dear mpolly: I too am looking for the same gear I believe, if its the one that at the top of the long rod. Ours fell off as well and probably found by someone in there bag of pop corn. I will let you know if I find it.
Jun 30, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Star 39 JetStar Popcorn Maker Logo
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
