Question about Britax Eclipse Si - Paris Convertible Car Seat
Britax Car Seat First Class SI
I took the cover off the car seat and straps!!! to wash the cover but have no clue how to put it back on??
  • 3 more comments
  • Anonymous Sep 07, 2008
    to loosen or tighten shoulder straps
  • jcwalker Sep 07, 2008
  • aj43 Nov 20, 2008
    I took the cover off to wash and now csant put seat back together
  • mns_1976 Nov 23, 2008
    I can't put the straps back :((
    can u please help????
  • Anonymous Apr 27, 2009
    i took the cover of to wash now i can't put the straps back
I took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Posted on Sep 27, 2008
Fitting instructions for Britax First Class SI child's car seat lost. Where can I get replacement instructions?
hi here are the uk instructions if you need a different country please comment back with your country and i will get back to you
http://www.britax.co.uk/media/143820/9.pdf
Mar 21, 2011 | Britax First Class SI - Vienna Infant Car...
Lost manual need help to replace covers and straps after cleaning
A manual is available here:
http://www.sjova.is/files/2006_9_18_First_Class_SI_BBO60404.pdf
Feb 24, 2011 | Britax First Class SI - Vienna Infant Car...
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
Polystyrene snapped britax first class
If you are a UK resident, then contact 01264 386034 or email service.uk@britax.co.uk who will be able to sell you the required part.
I hope this helps.
Aug 01, 2009 | Britax Eclipse Si - Paris Convertible Car...
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
Need to put car seat cove back on
This can be very tricky! Usually, you must put on the cover first, then guide the belt through the openings from the front. Turn the metal retainer clips sideways, and then anchor them on the back of the seat. I used to have one of these seats, sorry I do not still have the manual though. You can also try going to the company website for advice. Good luck.
May 20, 2009 | Safety 1st Vantage Point 22-560
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
Britax Eclipse Si - Paris Convertible Car Seat Logo
1,291 people viewed this question
Top Britax Baby Gear Experts
thegtw
Jennifer Rock
Jennifer Rock
Dorel UK
Dorel UK
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
